Newbie
pepsiman
Newbie
Hi,
So I was able to finally upload code from the RAGen successfully to my RA. However, I am having difficulty with setting up my AI Sol Blue...
I get an error that says 'class ReefAngelClass' has no member named 'AI'. Any thoughts?
Attached is my code..
- Contact:
Re: Newbie
What version of the libraries are you using? the AI support was added in to 0.8.5.19.
You should update your libraries to the latest:
http://forum.reefangel.com/viewtopic.php?f=8&t=2
If you are running 0.8.5.19, make sure you have this in your ReefAngel_Features.h file:
That will enable the AI support.
#define AI_LED-
pepsiman
Re: Newbie
Hi,
I have the updated libraries -
When I open the Features.h file, its two paragraphs with a space inbetween - I added it but it still gives me an error...anyother suggestions?
pepsiman
Re: Newbie
Hi Roberto - I've sent you an email...
Re: Newbie
If there was only 2 lines, you are opening the wrong file.
The ReefAngel_Features.h file is located at "Documents\Arduino\libraries\ReefAngel_Features"
Just copy and paste this:
Try this code to start and then we can work on getting it more customized:
#define DisplayImages
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define AI_LED
#endif // __REEFANGEL_FEATURES_H__
//Autogenerated file by RAGen (v1.1.0.126), (02/11/2012 16:45)
// RA_021112_1645.pde
#define DateTimeSetup
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
#define AI_LED
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_AI.h>
ReefAngel.AI.SetPort(highATOPin);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,4);
ReefAngel.AI.SetChannel(RoyalBlue,4);
ReefAngel.StandardATO(Port1);
ReefAngel.StandardHeater(Port3);
ReefAngel.Wavemaker1(Port5);
pepsiman
Re: Newbie
Hi Roberto - I got it to work perfectly...thanks so much for your help!! now my corals won't be burnt.
I have been fiddling around with the PMW Slope function, but I am a bit confused...
what do the values in ReefAngel.AI.SetChannel(White,PWMSlope(9,0,22,0,0,30,240,0)) mean?
I plugged it into the code (replacing ReefAngel.AI.SetChannel(White,4)) and it was uploaded successfully and the white light turned off - from surfing the forums, this is what my impression is:
For the White Light, at 9,00 AM from 22:00, go from 0% to 30% over 240 min? I can't figure out what the last zero means?
In any case, could you write me a snippet that does the following (or at least get me started):
(W,B,RB)
12:00 PM - 12:45 PM (1,0,4) to (5,8,8) over 20 min
12:45 PM - 13:00 (5,8,8) to (8,10,10) over 10 min
13:00 - 17:00 (8,10,10) to (15,10,10) over 240 min
17:00-19:00 (15,10,10) to (20, 10,10) over 10 min
19:00 - 23:00 (20,10,10) to (15,10,10) over 120 min
23:00 - 00:45 (15,10,10) to (2,8,8) over 10 min
00:45 -01:30 (2,8,8) to (1,0,4) over 5 min
01:30 - 12:00 PM (1,0,4)
in chart form:
..................W B RB Ramp (min)
12:00 PM ...5 8 8 20
12:45 PM ...8 10 10 10
13:00.........15 10 10 240
17:00.........20 10 10 10
19:00.........15 10 10 120
23:00..........5 10 10 20
00:45..........2 8 8 10
01:30 (AM)..0 0 4 5
Thanks Roberto - after this I've fully customized the RA to my needs.....(well until I get wifi
) thanks!!
(W,B,RB)
in chart form:
01:30 (AM)..0 0 4 5
pepsiman
Re: Newbie
Any one? I've been able to use the code in the first post from this thread (http://forum.reefangel.com/viewtopic.ph ... ping#p3354) but want to know how i can use the PMW Slope function for my needs above....
Re: Newbie
May I ask why I have such a complex waveform?
I'm typing on phone, so can't really code, but you will need to have several if statements.
For every step, you'll need something like this:
if (NumMins(hour(),minute()>720 && NumMins(hour(),minute()<765) ReefAngel.AI.SetChannel(White,PWMSlope(12,0,12,45,0,5,20,0)
wolfador
Re: Newbie
Here is my code for my Ai Nano
This ramps the lights up to 30/35/35 starting at 9am over 200/240/240 minutes. Then they stay at those values, from 1pm until 5pm where they start to ramp down over the same time period (200/240/240), ending at 9pm where they sit at 3/8/8 until 10pm where they switch to lunar mode which is controlled by the MoonPhase(), taking the B/RB to a max of 7% on "full moon"
This has worked well for me the past few months. I have the white ramping faster so when I am home after ~5pm from work I get to see the tank in a crisp blue color which makes the corals pop and they still get the "daylight" that they need while I am away.
if (hour()>=22 || hour()<9)
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.07);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.07);
ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,21,0,8,35,240,8));
ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,21,0,8,35,240,8));
pepsiman
Re: Newbie
HI Guys,
Thanks for your reply - I'll try your code John...I've been fildding around with my RA and basically have some of the code working below - except im abit confused about the if/else hour line.. right now it says If its between midnight (is 0 the correct number for midnight or is it 24?) or and 12 PM, the lights will be (W1, B0, RB 4), and if its between 12 PM and 1 PM, its gonna be W5,B8,WB8)
What is the code for minutes?
Like suppose I want to say between 12 PM and 12:30 PM? Is it (hour()>=12,30 && hour()<12,30)
Can't seem to figure it out...
if (hour()>=0 && hour()<12)
ReefAngel.AI.SetChannel(White,1);
ReefAngel.AI.SetChannel(Blue,0);
else if (hour()>=12 && hour()<13)
ReefAngel.AI.SetChannel(White,5);
ReefAngel.AI.SetChannel(Blue,8);
ReefAngel.AI.SetChannel(RoyalBlue,8);
Re: Newbie
If you need to do minutes too, it's easier to calculate by the number of minutes from midnight.
The same code I posted above:
This would check if the number of minutes from midnight is >720 and <765
I jut wanted to inform that the new libraries have a new waveform that could be used.
Instead of using PWMSlope, which slopes up, remains flat and slopes down, you can use the new PWMParabola, which will generate a parabola type of waveform, which seems to be what you are trying to accomplish. Parabola is a much better approximation to the sun path that the slope.
Just an idea.
Just an idea.
pepsiman
Re: Newbie
Hi Roberto,
Thanks for the help. Im not to clear about the PMWSlope function.
For example, in (White,PWMSlope(12,0,12,45,0,5,20,0)), what does the last 0 mean?
Also, I thought the PMW Slope function allows your to Ramp up to a target value, and leave it that way...but then you're saying that it ramps to a target value, and then back to the original value?
How can I code it such that it will ramp to a target value and stay that way until I give another command?
wolfador
Re: Newbie
Wait why was I not notified of this?rimai wrote: the new PWMParabola, which will generate a parabola type of waveform, which seems to be what you are trying to accomplish. Parabola is a much better approximation to the sun path that the slope.
Just an idea.
Re: Newbie
The PWM Slope will ramp up and stay there and ramp down.
The last number is the number which you would like to be returned if when the time is outside of the slope schedule.
Re: Newbie
wolfador wrote:Wait why was I not notified of this?
Check out the new example codes.
Download at http://www.reefangel.com/Download.ashx
- Contact:
Re: Newbie
I found out by looking at the libraries as well.wolfador wrote:Wait why was I not notified of this?rimai wrote: the new PWMParabola, which will generate a parabola type of waveform, which seems to be what you are trying to accomplish. Parabola is a much better approximation to the sun path that the slope.
Just an idea.
