Bus lock issue
Armetas
Bus lock issue
Post by Armetas »
Hello,
Recently I constantly get Bus Lock error on my Reef angel - in that time salinity, ph expansion, water level goes to 0. After it comes back some of the ports in second relay expansion start turn on for less than a second.
I've tried to switch off the wifi module - bus lock issue stopped to appear. Any ideas what is causing this and how to solve this?
Armetas
Re: Bus lock issue
Post by Armetas »
Here is also video how ph expansion behaves: https://drive.google.com/open?id=10gT8v ... B0ovzHudoq
Re: Bus lock issue
Try connecting the pH module straight to the relay box without a hub.
What happens?
Armetas
Re: Bus lock issue
Post by Armetas »
When I connect directly to relay box without hub I do not get Bus Lock, but still PH expansion is going up and down. When I turn off wifi extension from RA - numbers becomes stable
Re: Bus lock issue
That module may be compromised, then.
Try cleaning it with alcohol.
Brush it really good and blow air to avoid water build up.
Armetas
Re: Bus lock issue
Post by Armetas »
Ok some updates: I've disconnected bluetooth attachement and connected Wifi module directly to ReefAngel - everything is stable now. I see that cables that connects from RA to Bluetooth and RA to Wifi are different - could this be a reason? Or any suggestions why this is happening?
