Thanks to Curt, I've been using seasonal temps flawlessly for a while now, and love it!
https://forum.reefangel.com/viewtopic.php?f=12&t=6622
However, I'd now like to ramp my lights several times a day so my corals don't get blasted with max light intensity all day long. can either be randomly (like cloudy periods) or one hour up...one down...one up...
any idea how I might code that?
Ramping leds up multiple times a day
- Contact:
Re: Ramping leds up multiple times a day
I have an idea or 2 but need some time to write it down.
You are just wanting to ramp up to 100% and back down multiple times and not be related to the seasonal temperatures, correct?
Reefology
Hey Curt, no rush at all and thanks a bunch.
correct not related to seasonal temps but would still like to control max intensity via the portal as I'm doing now.
Reefology
fyi, heres my latest code:
void SeasonalDaylight ()
static int daylightArray[][4] = {
{13,0,22,0}, // default in case of error in month=0 (May)
{15,0,22,0}, //January (winter)
{14,30,22,0}, //February (winter)
{14,0,22,0}, //March (early spring)
{13,30,22,0}, //April (spring)
{13,0,22,0}, //May (spring)
{12,30,22,0}, //June (early summer)
{12,0,22,0}, //July (summer)
{12,30,22,0}, //August (summer)
{13,0,22,0}, //September (early fall)
{13,30,22,0}, //October (fall)
{14,0,22,0}, //November (fall)
{14,30,22,0} //December (early winter)
// Port 2 is power supply for Day lights
ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(
daylightArray[month()][0],
daylightArray[month()][1],
daylightArray[month()][2],
daylightArray[month()][3],
InternalMemory.PWMSlopeStartD_read(),
InternalMemory.PWMSlopeEndD_read(),
InternalMemory.PWMSlopeDurationD_read(),
ReefAngel.PWM.GetDaylightValueRaw()
TODO comment out the next line if the power supply for the lights is not needed
and the lights are plugged into a power strip. Otherwise, if the lights
are plugged into the relay, you will need to toggle the port to turn
the lights off
ReefAngel.StandardLights(Port2, daylightArray[month()][0], daylightArray[month()][1],
daylightArray[month()][2], daylightArray[month()][3]);
}//end SeasonalDaylight
void SeasonalActiniclight ()
static int actinicArray[][4] = {
{12,30,22,30}, // default in case of error in month=0 (May)
{14,30,22,30}, //January (winter)
{14,0,22,30}, //February (winter)
{13,30,22,30}, //March (early spring)
{13,0,22,30}, //April (spring)
{12,30,22,30}, //May (spring)
{12,0,22,30}, //June (early summer)
{11,30,22,30}, //July (summer)
{12,0,22,30}, //August (summer)
{12,30,22,30}, //September (early fall)
{13,0,22,30}, //October (fall)
{13,30,22,30}, //November (fall)
{14,0,22,30} //December (early winter)
// Port 1 is power supply for Actinic Lights
ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(
actinicArray[month()][0],
actinicArray[month()][1],
actinicArray[month()][2],
actinicArray[month()][3],
InternalMemory.PWMSlopeStartA_read(),
InternalMemory.PWMSlopeEndA_read(),
InternalMemory.PWMSlopeDurationA_read(),
ReefAngel.PWM.GetActinicValueRaw()
the lights off
ReefAngel.StandardLights(Port1, actinicArray[month()][0], actinicArray[month()][1],
actinicArray[month()][2], actinicArray[month()][3]);
}//end SeasonalActinics
InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
//ReefAngel.ActinicLights( Port1 );
//ReefAngel.DayLights( Port2 );
// Light code
SeasonalDaylight();
SeasonalActiniclight();
ReefAngel.Relay.DelayedOn(Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
//ReefAngel.PWM.DaylightPWMSlope();
//ReefAngel.PWM.ActinicPWMSlope();
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
ReefAngel.Relay.Off(Port6);
ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds
// DC pumps....................................
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800)
ReefAngel.DCPump.Mode=ReefCrest;
ReefAngel.DCPump.Speed=75;
// Night/Quiet mode
else if (hour()>=2 && hour()<8 ) // 2am to 8am
ReefAngel.DCPump.SetMode( Gyre,40,10 );
else if (hour()>=15 && hour()<19) // 3pm and 7pm
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
//Storm mode
else if (hour()>=1 && hour()<2) // 1am and 2am
ReefAngel.DCPump.SetMode( Else,70,15 );
else if (hour()>=11 && hour()<12) // 11am and 12pm
ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
else if (InternalMemory.DCPumpMode_read()==11)
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "" );
ReefAngel.DDNS( "" ); // Your DDNS is
