Reef Angel Wifi Adress
Hi Guys
How do I change my Reef Angel wifi address in the Portal
Re: Reef Angel Wifi Adress
It does it automatically as soon as your RA connects to the server
Okay. Thanks. But Still struggling
When setting up my Wifi attachment, The Wifi wizard goes thru everything
Everything is true getting IP adress ect. but the bottom line reads....
Trying to connect to your router..........
Thanks! Will givecit a go....
Just one think... I says trying to connect to router
But I have a slow flashing green LED. That means its
Connected Right? But is trying to connect to router.
Strange
Strange
Okay.... I installed teraterm, downloaded the zip file, made changes as nessasary,rimai wrote:Try this:
https://forum.reefangel.com/viewtopic.php?f=3&t=4601
Changed baud rate to 57600, and ran the macro.
Macro ran Fine... Everything read “AOK” But now my WiFi attachment has a blinking
Blue and Green Light.
What to do Now?
Yes. SSID and Passphrase changedrimai wrote:Did you change the ssid and password?
It is case sensitive.
Do you happen to have a space?
If so, you need to use $ instead of space.
I have an underscore "_" in my SSIDrimai wrote:Do you happen to have a space?
This is what I get.rimai wrote:Do you happen to have a space?
P.S. Passphrase edited
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid GlidePath_Wifi'
wait 'AOK'
sendln 'set wlan pass **********'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
This is the macro file. Are you sure you ran it?
Did you get the messageboxes at the start and end?
Yes. Got the message boxes at the beginning and then againrimai wrote:This is the macro file. Are you sure you ran it?
at the end.
If I run the macro, The Wifi attachment then has a green and blue light blinking.
If I run the Wifi utility, I have a Slow blinking Green light with message “ Trying to
Trying to connect to router is normal.
It just means that it wasn't able to setup upnp on your router.
Not sure why you get blue when running the macro.
If you enter the correct ssid and passphrase, it should connect.
Can you pull the "get e" log after you run the wifi utility?
Okay... So after a bit of a cool down period I tried again.
Using Wifi utility: After selecting serial port and clicking Connect I get this message:
**ERROR- Please disconnect and reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
Then Using the macro:
At first I ran 9600 baud rate and got a hole lot of "hieroglyphics" on the screen.
Then I tried 57600 and got this message:
HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Wed, 24 Jul 2019 07:59:19 GMT
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
Now Currently Nothing is connecting to the Wifi Attachment.
Connection: close
Content-Length: 326
</BODY></HTML>
You didn't run the macro correctly.
It must be at 57600 before you run it.
