Ask in here.
jcjrogersstar
Posts: 43 Joined: Thu Jan 04, 2018 10:47 pm
Post
by jcjrogersstar » Mon Apr 13, 2020 7:19 pm
I just added my Ca Reactor and was adding code to shut it down if tank pH (not Expansion pH) gets below 7.75. Even though my pH is well above that, the ports turn-off immediately once code is loaded and even after a second reboot. I verified it was these statements by remming them out. What am I missing?
if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box1_Port1 ); ///Turns off Carbon Doser if tank pH <= 7.75.
if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box1_Port6 ); //Turns off Ca Reactor Ca Pump if tank pH <= 7.75.
if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box2_Port8 ); //Turns off Ca Reactor Fill Pump if tank pH <= 7.75.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.AddRANet(); // RANet Add-On Module
ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit; //UV and UV Pump-off.
ReefAngel.FeedingModePortsE[1] = Port7Bit; //Skimmer-off.
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[1] = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[2] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[1] = Port1Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPortsE[1] = Port1Bit; // Powermodule Fixture On.
// Use T2 probe as temperature and overheat functions
InternalMemory.OverheatTemp_read(); // trying this code to see if it pulls internal memory overheat temp.
ReefAngel.Relay.On( Box1_Port1 ); // Carbon Doser (CaR CO2 Doser) always on.
ReefAngel.Relay.On( Box1_Port3 ); // Gyres always on.
ReefAngel.Relay.On( Box1_Port6 ); // Calcium Reactor Recirculation Pump (CaR Recirc Pump) always on.
ReefAngel.Relay.On( Box1_Port8 ); // UV Pump always on.
ReefAngel.Relay.On( Box2_Port1 ); // Powermodule Lights/Fans always on.
ReefAngel.Relay.On( Box2_Port4 ); // Return Pump always on.
ReefAngel.Relay.On( Box2_Port8 ); // Calcium Reactor Fill Pump (CaR Fill Pump) always on.
InternalMemory.FeedingTimer_write(7200); // sets feeding mode to 2 hours (only used for coral feeding)... shuts down UV bulb, UV pump, and skimmer.
ReefAngel.StandardLights( Box2_Port3 ); //Using Internal Memory Standard Lights to run Refugium Light.
ReefAngel.StandardHeater2( Box1_Port2 );
ReefAngel.StandardHeater2( Box2_Port5 );
ReefAngel.StandardFan2( Box2_Port6 ); //Sump Fans
ReefAngel.Relay.DelayedOn( Box2_Port7 ); //Skimmer
ReefAngel.WaterLevelATO( 1,Box3_Port1); //ATO pump-DC relay box-new program.
//ReefAngel.PWM.DaylightPWMSlope(); - not using PWM for main LEDs
//ReefAngel.PWM.ActinicPWMSlope(); - not using PWM for main LEDs
ReefAngel.StandardHeater( Box1_Port7,788,796 ); //Manages UV bulb on/off based on tank temp.
ReefAngel.DosingPumpRepeat1( Box3_Port2 ); // Pump dosing kalk-DC Relay Box.
ReefAngel.DosingPumpRepeat( Box1_Port4,0,60,2700 ); // Stirrer on/off.
boolean buzzer=false;
// if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.Params.PH > 844 ) ReefAngel.Relay.Off( Box3_Port2 ); //Turns off Kalk Stirrer dosing if tank pH > 8.44.
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX1+BrIhUnNJiKHbFL6wohK41+33EQ2nHfFo=
// RA_STRING2=U2FsdGVkX1+EmuJjuPrMWBEHac9zWSjiW8ZytHk/q+M=
// RA_STRING3=Chloe's House-2.4
// RA_LABEL LABEL_PORT11=Main LEDs
// RA_LABEL LABEL_PORT12=Heater 2
// RA_LABEL LABEL_PORT13=Gyre Pumps
// RA_LABEL LABEL_PORT14=Kalk Stirrer
// RA_LABEL LABEL_PORT15=Salt Mix Tank
// RA_LABEL LABEL_PORT16=Co2 Control
// RA_LABEL LABEL_PORT17=Unused
// RA_LABEL LABEL_PORT18=Unused
// RA_LABEL LABEL_PORT21=Main T5s
// RA_LABEL LABEL_PORT22=Light Fans
// RA_LABEL LABEL_PORT23=Refugium LED
// RA_LABEL LABEL_PORT24=Return Pump
// RA_LABEL LABEL_PORT25=Heater 1
// RA_LABEL LABEL_PORT26=Sump Fans
// RA_LABEL LABEL_PORT27=Skimmer
// RA_LABEL LABEL_PORT28=ATO Pump
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Mon Apr 13, 2020 11:58 pm
I don't see nothing wrong.
Are you saying that if you comment these lines, the port remains on?
jcjrogersstar
Post
by jcjrogersstar » Tue Apr 14, 2020 11:29 am
Yes, a couple of "//" in front of each one, and they are all on. I even changed one to < only (no =), and they were all still off. I wondered if they needed a > statement as well, but I've never noticed having to do that.
Post
by rimai » Tue Apr 14, 2020 12:55 pm
Are they on the RANet or USB connected relay boxes?
jcjrogersstar
Post
by jcjrogersstar » Tue Apr 14, 2020 2:00 pm
rimai wrote: Are they on the RANet or USB connected relay boxes?
Both boxes. 2 on an Expansion Box, and 1 on my old original box with a serial cable (looks like a serial cable).
Post
by rimai » Tue Apr 14, 2020 2:33 pm
Why do you have RANet on your code then?
jcjrogersstar
Post
by jcjrogersstar » Tue Apr 14, 2020 5:08 pm
rimai wrote: Why do you have RANet on your code then?
Good question. I'm not sure what RA Net is, but my original code was on a RA+ with Cloud wifi. I then migrated to RA* and use the ethernet connection. I do most programming with the Web Wizard and then a little code I've gotten help with. Now, I also run a D/C Expansion module if that might have anything to do with it. My guess is, it was in my original code, and I never messed with it. Do I need to remove?
Post
by rimai » Tue Apr 14, 2020 5:16 pm
If you are not using it, remove it.
But the issue you are having still is a mystery.
It should work as you posted.
I am not understanding why it is not.
jcjrogersstar
Post
by jcjrogersstar » Tue Apr 14, 2020 6:50 pm
rimai wrote: If you are not using it, remove it.
I removed it but same thing... all three ports are "auto" off.
Also, this is the code that allows all 3 ports to default to "auto" on.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
//ReefAngel.AddRANet(); // RANet Add-On Module (don't know why I had this).
//if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box1_Port1 ); //Turns off Carbon Doser if tank pH <= 7.75.
//if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box1_Port6 ); //Turns off Ca Reactor Ca Pump if tank pH <= 7.75.
//if ( ReefAngel.Params.PH <= 775 ) ReefAngel.Relay.Off( Box2_Port8 ); //Turns off Ca Reactor Fill Pump if tank pH <= 7.75.
jcjrogersstar
Post
by jcjrogersstar » Wed Apr 15, 2020 1:53 pm
I used the CO2 control code below, and that appears to work... meaning it recognizes the 'on' value as all three ports default "auto" on with my pH well over 7.85. However, I don't know if they will shut-off at a pH of 7.75
ReefAngel.CO2Control( Box1_Port1,775,785 ); //Turns off Carbon Doser (CaR CO2 Doser) if tank pH <= 7.75 and back on at 7.85.
ReefAngel.CO2Control( Box1_Port6,775,785 ); //Turns off Ca Reactor Recirculation Pump (CaR Recirc Pump) if tank pH <= 7.75 and back on at 7.85.
ReefAngel.CO2Control( Box2_Port8,775,785 ); //Turns off Ca Reactor Fill Pump (CaR Fill Pump) if tank pH <= 7.75 and back on at 7.85.
Another question. If I were to lose one of 3 connections to my Ca reactor, I would have a nasty flood as the feed pump would keep running. Therefore, I want to add a failsafe based on my sump water level (e.g. ATO water level). I use the Multichanel water level expansion for my ATO (channel 1). Would this be the correct failsafe code?
if ( ReefAngel.WaterLevel.GetLevel(1) <= 63 ) ReefAngel.Relay.Off( Box1_Port1 ); //Turns off Carbon Doser if sump water level <= 63.
if ( ReefAngel.WaterLevel.GetLevel(1) <= 63 ) ReefAngel.Relay.Off( Box1_Port6 ); //Turns off Ca Reactor Recirculation Pump if sump water level <= 63.
if ( ReefAngel.WaterLevel.GetLevel(1) <= 63 ) ReefAngel.Relay.Off( Box2_Port8 ); //Turns off Ca Reactor Fill Pump if sump water level <= 63.
Post
by rimai » Wed Apr 15, 2020 5:50 pm
The code you used looks fine.
jcjrogersstar
Post
by jcjrogersstar » Wed Apr 15, 2020 6:10 pm
rimai wrote: The code you used looks fine.
