Dimming module
bmhair03
Dimming module
How would I modify my code so the moonlight isn't so bright? Is it possible to turn dimmer port off ? So its only on at night?
I do currently have it coded for moon phase through the wizard. Moonlight is working but seems a little to bright for my liking .I know full moon is 3 days away but hoping there is a way.
Thanks.
Thanks.
bmhair03
Re: Dimming module
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port2,7,20,19,30 );
ReefAngel.StandardLights( Port4,7,20,19,30 );
ReefAngel.StandardHeater( Port6,720,815 );
ReefAngel.SingleATO( true,Port8,10,0 );
ReefAngel.PWM.SetChannel( 0, MoonPhase() );
ReefAngel.Portal( "bmhair03" );
Re: Dimming module
You can multiply the moonphase by a certain amount.
So, if you want 50%, just use MoonPhase() * 0.5
bmhair03
Re: Dimming module
Thank you for that. i got that dialed in and run the dimmer module power off a standard light outlet to give me the on/off control.
Is there a way to force the ATO to run for a set amount of time(like 3 sec) when needed "true"but also still have the time out of 10 sec. in place? My small tank seems to make the ATO run short burst like 1 secs but often all during the day.I believe the fact the sump is so small that the first rush of water is raising the float ,but i cant fit a tube around the sensor to buffer the float there is no more room.I already modified the last chamber of the BC14 to fit a mp10 dryside.
bmhair03
Re: Dimming module
Here's my current code.
ReefAngel.WaterChangePorts = Port4Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port3,19,0,6,0 );
ReefAngel.PWM.SetChannel( 0, MoonPhase()*45 );
Re: Dimming module
Try this:
This should make it go only once an hour
ReefAngel.SingleATO( true,Port8,10,1 );
bmhair03
Re: Dimming module
After .50 there seems to be no difference? I'm at .33 now .Moonlight stops working at .25 . Is it because I'm using a dimming module not a lunar module to control it?
Re: Dimming module
It may not like the floating point.
Try division then.
MoonPhase()/4 is basically the same a *0.25
Try division then.
bmhair03
Re: Dimming module
Thank you I had forgotten to put the 0 in. rebooted it and its working great.
Thank once again. My sloppy coding always gets me.!
