I set al my codes with the web wizard, but some things are not working properly.
• UV in port 13 is suppose to be always on, and turn of if port 11 is off, but is off and tier to port 3.
• Wavemaker was set to 3600-7400 sec random in port 6, and opposite in port 16, but is turning like every 30 sec.
• Fuge light is set on timer for 10:00 PM to 12:00 AM, but is always on.
• Temp 2 is set to F when all the others are C.
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit;
ReefAngel.WaterChangePortsE[1] = Port1Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[1] = Port1Bit;
ReefAngel.LightsOnPortsE[1] = 0;
// Use T3 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.DelayedOn( Box1_Port3 );
ReefAngel.WaterLevelATO( Box1_Port5 );
ReefAngel.DosingPumpRepeat1( Port5 );
ReefAngel.Wavemaker2( Port6 );
ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port6 ) );
ReefAngel.StandardLights( Box1_Port7 );
ReefAngel.StandardFan3( Port7 );
if ( ReefAngel.Relay.Status( Port3 ) ) ReefAngel.Relay.Off( Box1_Port3 );
ReefAngel.Portal( "symon_say" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT8=N/A
// RA_LABEL LABEL_PORT27=N/A
// RA_LABEL LABEL_PORT2=Sump Led
// RA_LABEL LABEL_PORT16=Left Gyre
// RA_LABEL LABEL_PORT1=DCP 8000
// RA_LABEL LABEL_PORT7=Fan
// RA_LABEL LABEL_PORT26=N/A
// RA_LABEL LABEL_PORT15=ATO
// RA_LABEL LABEL_PORT28=N/A
// RA_LABEL LABEL_PORT23=N/A
// RA_LABEL LABEL_PORT13=UV
// RA_LABEL LABEL_PORT18=N/A
// RA_LABEL LABEL_PORT3=Skimmer
// RA_LABEL LABEL_PORT22=N/A
// RA_LABEL LABEL_PORT11=DCP 6500
// RA_LABEL LABEL_PORT25=N/A
// RA_LABEL LABEL_PORT12=Dosing pump
// RA_LABEL LABEL_PORT5=Sump Wave
// RA_LABEL LABEL_PORT14=Left AP700
// RA_LABEL LABEL_PORT6=Right Gyre
// RA_LABEL LABEL_PORT17=Fuge Kessil
// RA_LABEL LABEL_PORT4=Right AP700
// RA_LABEL LABEL_PORT21=N/A
// RA_LABEL LABEL_PORT24=N/A
