How to set a pump to turn on every half hour
symon_say
Post by symon_say »
Hi
I have a pump under dosing station and i need it to turn on every half hour for 10 minutes, I try it with the dosing pump set, but sometimes It doesn't start and beginning of the hour. How can i code the outlet to turn on every half hour starting at the hour 9:00, 9:30, 10:00 etc... and if the controller restart it will start the cycle with the hour.
This is the code i have:
ReefAngel.DosingPumpRepeat( Port5,0,30,600 );
Re: How to set a pump to turn on every half hour
Your code looks good.
Can you explain better what the problem is?
