So i finally got a pH probe and got it calibrated and it seems to be working fine. But I can't pull any graphs or store any data from it or the temp probe through the uapp or through the android app. What do I need to do or what am I doing wrong, what should i check? TIA
I want to do this so that I can use a dosing pump to add kalk during the night to keep my pH raised and stable like what ACI aquaculture does.
Sent from my Pixel 4 XL using Tapatalk
Graphs and data
Re: Graphs and data
Try updating the wifi attachment: https://forum.reefangel.com/viewtopic.php?f=3&t=4601
- mav3rick478
Re: Graphs and data
Thanks Roberto that seemed to work but with a little twist, the safari browser on my ipad that i was using Uapp is working great, shows data and graphs. But if i go to my or any computer and try Uapp there, add the controller with all the same settings as my iPad it gives me the following error, "Reef Angel Controller unable to process controller data!" Android app still wont show graphs but will show reading from my probes.
