if you enable wifi athentication, none of the available apps will work.
If you enable the date/time feature, it will use up a lot of memory.
Dim LEDs with PWM expansion and alternate wavemaker
Re: Dim LEDs with PWM expansion and alternate wavemaker
I can compile with the folowing features:
wifi
wdt
custom menu
pwm expansion
version menu
display led pwm
wifi
wdt
custom menu
pwm expansion
version menu
display led pwm
So will the Wifi not work because of the custom code or is there another reason that Wifi will not work? And I can forgo the clouds as long as it's still possible to have alternating wavemakers, and the sunrise/sunset of the LED's, hopefully with ability to set times for actinics (channels 2 and 3) seperate from daylight (channels 0 and 1). Thank you so much for the help!
Yes, wifi is in the feature list I typed above
Oh thank you, I would love to have that code if you could please!
This is the fixed up internal memory file:Aricml wrote:Oh thank you, I would love to have that code if you could please!
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(15);
InternalMemory.MHOnMinute_write(30);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(7);
InternalMemory.StdLightsOnHour_write(14);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.StdLightsOffMinute_write(30);
InternalMemory.DP1Timer_write(4);
InternalMemory.DP2Timer_write(4);
InternalMemory.LEDPWMActinic_write(20);
InternalMemory.LEDPWMDaylight_write(20);
InternalMemory.WM1Timer_write(10);
InternalMemory.WM2Timer_write(15);
InternalMemory.HeaterTempOn_write(766);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(774);
InternalMemory.ChillerTempOff_write(770);
InternalMemory.PHMax_write(830);
InternalMemory.PHMin_write(540);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(140);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
Thanks binder, and rimai, if you could compile that code I would really appreciate it.
