UAPP PROBLEMS
All things Uapp related, this can be idea requests, issues, or just any Uapp dicussion
CASPAR
UAPP PROBLEMS
Post by CASPAR »
AS OF YESTERDAY MORNING MY UAPP HAS STOPPED REFRESHING, ANY IDEAS ANYONE?
brennyn21
Re: UAPP PROBLEMS
Post by brennyn21 »
Do you get an error? Can you try logging out and back in again?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
YES HAVE LOGGED OUT THEN BACK ON AND STILL GET ERROR "FAILED TO REFRESH DATA"
THIS LINE I MADE SURE IS IN MY CODE "ReefAngel.Portal( "CASPAR" );"
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
UAPP ON PHONE AND COMPUTER DOES NOT REFRESH BUT THE OLD APP ON MY PHONE DOES IN BOTH HOME AND AWAY MODE
brennyn21
Re: UAPP PROBLEMS
Post by brennyn21 »
Did your router or port forwarding change? Can you access your controller by going to your publicIP:2000?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
IF I PUT MY IP IN I JUST GET Reef Angel Controller Web Server
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
ALSO JUST GOT EMAIL NOTIFICATION ABOUT 10 MINUTES AGO THAT SAID REEF ANGEL HAS RE ESTABLISHED CONNECTION, BUT STILL DOESNT WORK
brennyn21
Re: UAPP PROBLEMS
Post by brennyn21 »
If you can see the webserver, then it should be working, does it let you change the modes or turn on or off an outlet?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
I DONT SEE NOTHING BUT THE WORDS REEF ANGEL CONTROL WEB SERVER NOTHING ELSE.
FAR AS CHANGING STATUS OF THE RELAY IT WILL NOT DO THAT EITHER JUST SAYS SOMETHING TO THE EFFECT OF FAILED TO UPDATE COMMAND AT BOTTOM OF SCREEN IN RED
brennyn21
Re: UAPP PROBLEMS
Post by brennyn21 »
Can you try deleting the controller and then readding it?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
THAT DID IT, WHAT MAY HAVE CAUSED THIS?
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
BRENNY21 I SENT YOU A PM....
brennyn21
Re: UAPP PROBLEMS
Post by brennyn21 »
I wonder if your IP changed and the Uapp didn't update correctly I will do some investigating. I responded to your PM
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
Post by CASPAR »
MORE THAN LIKELY IP MAY HAVE CHANGED DUE TO SPECTRUM DOING AN OVERNIGHT MAINTENACE THING, AND TRUST ME IT SCREWED UP ALOT OF CRAP!!!
