Hey Brennyn,
What is the most recent hardware version for the multi channel water level expansion? I’m having issues with bus locks when I have mine hooked up. The silkscreen on the one I have shows reversion 1.1. I’m trying to troubleshoot and trying to figure out if I possibly have an older version or maybe a bad board.
Charlie
Current Hardware Version - Multi Channel Water Lever?
Piper
- brennyn21
Re: Current Hardware Version - Multi Channel Water Lever?
So 1.1 is the last version released by Roberto, I made 1.2 which uses USB C and a newer ADC Chip. Does yours have any corrosion on the connector? Send me a PM and I can just send out a new module so you don't have to buy the whole kit if yours is faulty.
Sincerely, Brennyn
Piper
Thanks, Brennyn. No corrosion on the board, connector, or the hub. I’ll shoot you a PM. Thanks!
