I am unboxed and ready for setup of my RA. I just completed my DIY Led fixture and when ordering my drivers RapidLed recommended I choose the Mean Well ELN-60-48P dimmable drivers. Is this ok in regards to the RA controlling them and in addition I ordered the PWM Port lead wire and not the PWM-analog is this ok for my setup? And last but not least will my drivers need to be plugged into the relay box or just a wall outlet with the powering on and off being strictly through the ramp up slope code I have seen mentioned in the forums?
Thanks so much for any help looking forward to being a part of the RA Family!!!
Couple questions regarding Meanwell drivers
Re: Couple questions regarding Meanwell drivers
You are all set
You can leave the drivers on the wall.
Great so I guess my next step would be reallocating the daylight, moonlight, and actinic plugs on relay box. Would it be possible to rename/assign 1 for a GFO reactor that also adds a function on the display to turn on and off via the joystick?rimai wrote:You are all set
Yes, you could do that. You would need to use the Custom Menu and then have one entry turn it on and then other could turn it off. There are lots of ways you could handle this.Saltydogg wrote: Great so I guess my next step would be reallocating the daylight, moonlight, and actinic plugs on relay box. Would it be possible to rename/assign 1 for a GFO reactor that also adds a function on the display to turn on and off via the joystick?
Something like:
void MenuEntry1()
// turn on Port 1
ReefAngel.Relay.On(Port1);
void MenuEntry2()
// turn off port 1
ReefAngel.Relay.Off(Port1);
That's just the sample of how the code would be. You would still need to create the menu entry labels, but that code would turn on port 1 when selected and turn off port 1 when selected.
