Quick question. If I calibrate the PH probe, and then update the code on my controller (for say... WIFI here in a couple months ) would I need to recalibrate, or would it save the settings?
It should save the settings. The settings are stored in the internal memory. The only way it would change is if you were to reload the Internal Memory values from the INO/PDE file OR if you were to change the internal memory value from one of the apps.
Should be mutually exclusive. Should not matter at all.
binder wrote:OR if you were to change the internal memory value from one of the apps.
Are you saying I can change this from inside the client app? I have been wanting to do this but been too lazy to change and reload my memory file. Thx
