one more for the heater
miked
Post by miked »
where do i set the port off limit for the heater. say i want the heater outlet to turn off, in case the temp raises due to heater malfunction, at 83 degrees...how do i set the 83 degrees...? not been able to find it. thanks, in the meantime i will continue the search.
Re: one more for the heater
this just depends on how you code your file. if you are using the internal memory, then you have to set it the heater off temp to 830. just interpret your temperature as always having a decimal point and remove the point. 830 == 83.0 765 == 76.5
