Setting up Dosing pumps
najluni15
Post by najluni15 »
Hi all,
I am just getting my reef angel setup and have everything going correctly, but now it is time to setup my dosing pumps. When I add the dosing pumps to my code it says the file is too big. Looking around on the forum it looks like i can cut some fluff out of my code, but am not sure what i can remove. Please see my file and let me know if you have any ideas. I just have my ato, lights, pumps, skimmer, and heater on the file. Not sure if im doing it right. Also, how do you program the dosing pumps to go on at an exact time in seconds and off at a given time? It is the reef angel doser.
// Autogenerated file by RAGen (v1.2.1.158), (03/10/2012 15:20)
// RA_031012_1520.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 8
#define SIMPLE_MENU
ReefAngel.Relay.On(Port3);
// Specific functions
ReefAngel.StandardATO(Port1,15);
ReefAngel.StandardLights(Port2,21,0,11,0);
ReefAngel.StandardLights(Port4,12,0,21,0);
ReefAngel.StandardLights(Port5,8,0,22,0);
ReefAngel.StandardHeater(Port6,788,792);
ReefAngel.DosingPump1(Port7);
ReefAngel.DosingPump2(Port8);
Thanks so much!!!
Re: Setting up Dosing pumps
Open RAGen
Move to Features tab
Uncheck Date/Time Setup
Uncheck Expansion Relays
Click Save
najluni15
Post by najluni15 »
Thank you for the help. How would I structure the code to make the dosing pump 1 come on at 3 am for 45 seconds and 5 am for 45 seconds, then the second pump come on at 10am for 95 seconds?
Try this:
  if (hour()<4)
    ReefAngel.DosingPump(Port7, 1, 3, 0, 45);
    ReefAngel.DosingPump(Port7, 1, 5, 0, 45);
  ReefAngel.DosingPump(Port8, 2, 10, 0, 95);
najluni15
Post by najluni15 »
Thanks....So what does the (1) and the (2) signify in the codes? And could i copy the code you made exactly to make dosing pump on port 7 come on at 3 and then at 5 for 45 seconds, then port 8 come on at 10 for 95 seconds?
Sorry for the kinda repetetive questions but I tried to figure it out and did it wrong
najluni15 wrote:Thanks....So what does the (1) and the (2) signify in the codes? And could i copy the code you made exactly to make dosing pump on port 7 come on at 3 and then at 5 for 45 seconds, then port 8 come on at 10 for 95 seconds?
The 1 and 2 are references to some built-in timers in the libraries. There are only 2 timers (maybe 3) that are not used by other functionality that are available for your use. One timer can be used at a time (ie, one timer per dosing pump).
Yes, the code that was provided should do exactly what you are talking about. You would just need to use that code instead of the DosingPump(Port7) and DosingPump(Port8) lines in your original file.
