lights
ryanmell
lights
I have a current sundial mh pc combined light with built in timers and only one power cord so i am forced to use the built in timers to use the acntic pc's for sunrise and sunset my question is can i use the mh function but keep that outlet always on, i want to keep it on the reef angel in case i need to turn the light off remotely due to heat and want to be able to use the overheat function
ryanmell
Re: lights
i tried to do it through ragen and it only lets me pick always on or mh but not both is there a certain outlet i need to use?
Re: lights
Maybe I misunderstood the question then. Can you explain again what you are trying to do?
ryanmell
Re: lights
The light only has 1 power cord and has 2 timers on the light, one for 2 34w power compacts and1 for a 150w mh. I need the outlet to be always on but also want to use the mh setting in case the power goes out and the overheat setting to turn off the light if it gets to hot,
Re: lights
The overheat is easy.
You can just pick the port on RAGen on "Ports Toggle During Modes"
The MH delay can be achieved by using the schedule from 12:00am to 11:59pm.
That way you have the MH function and it will stay on all the time
