#define AutoTopOff 1
#define Refuge 2
#define MHLight 3
#define Actinic 4
#define WaveController 5
#define Heater 6
#define Fans 7
#define Pumps 8
#define NW1 0
#define NW2 1
#define NW3 2
#define Blue 3
#define Green 4
#define Red 5
// RB Actinic
// Violet Daylight
static bool fOverride = false;
static bool rOverride = false;
boolean ForceCloud=false;
boolean ForceLightning=false;
byte PWMChannel[]={
0,0,0,0,0,0};
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feed Fish";
prog_char menu2_label[] PROGMEM = "Feed Coral";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Actinic LEDs";
prog_char menu6_label[] PROGMEM = "100% Daylight LEDs";
prog_char menu7_label[] PROGMEM = "Refuge LEDs";
prog_char menu8_label[] PROGMEM = "Force Clouds";
prog_char menu9_label[] PROGMEM = "Storm Mode";
menu1_label,
menu2_label,
menu3_label,
menu4_label,
menu5_label,
menu6_label,
menu7_label,
menu8_label,
menu9_label
void TogglefOverride()
if ( fOverride )
fOverride = false;
fOverride = true;
void TogglerOverride()
if ( rOverride )
rOverride = false;
rOverride = true;
void MenuEntry1() //"Feed Fish"
ReefAngel.FeedingModeStart();
void MenuEntry2() //"Feed Coral"
/* // clear the screen
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, "Feeding Coral");
// Turn off the return port first
ReefAngel.Relay.Off(Port8);
ReefAngel.Relay.Write();
char msg[8];
bool done = false;
int t;
byte row;
// Have 2 loops / passes
// The first pass will just wait 5 minutes (or whatever value is stored in the feeding timer)
// The second pass will turn off the wavemaker port and wait 5 minutes
// Then the loop will finish and we turn the ports back on
for ( byte i = 0; i < 2; i++ )
sprintf(msg, "Phase %d", i+1);
// leave a blank row and start on the 3rd line
row = MENU_START_ROW*(i+3);
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, row, msg);
if ( i == 1 )
// second time through, we enter phase 2, so shutoff the wavemaker now
ReefAngel.Relay.Off(Port5);
// start the feeding timer
ReefAngel.Timer[FEEDING_TIMER].Start();
do
// just loop until the joystick button is pressed or the timer is triggered
// then break out of the loop and proceed
#if defined WDT || defined WDT_FORCE
wdt_reset();
#endif // defined WDT || defined WDT_FORCE
// update the timer on the screen
t = ReefAngel.Timer[FEEDING_TIMER].Trigger - now();
if ( (t >= 0) && ! ReefAngel.Timer[FEEDING_TIMER].IsTriggered() )
ReefAngel.LCD.Clear(DefaultBGColor,60+(intlength(t)*5),row,100,row+8);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,60,row,t);
delay(200); // to keep from redraw flicker on timer
done = true;
if ( ReefAngel.Joystick.IsButtonPressed() )
// joystick button pressed, so we stop
done = true;
} while ( ! done );
wdt_reset();
// reset the variable for the inner do while loop
done = false;
// Restore ports & return to the main screen
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port5);
ReefAngel.ExitMenu();
void MenuEntry3()
ReefAngel.ATOClear();
ReefAngel.DisplayMenuEntry("Clear ATO");
void MenuEntry4()
// ReefAngel.SetupCalibratePH();
// ReefAngel.DisplayedMenu = ALT_SCREEN_MODE;
void MenuEntry5() //"Actinic LEDs"
TogglefOverride();
// ... set the channels on
ReefAngel.PWM.SetChannel(NW1,15);
ReefAngel.PWM.SetChannel(NW2,15);
ReefAngel.PWM.SetChannel(NW3,15);
ReefAngel.PWM.SetChannel(Blue,15);
ReefAngel.PWM.SetChannel(Green,15);
ReefAngel.PWM.SetChannel(Red,15);
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetDaylight(15);
void MenuEntry6() //"100% Daylight LEDs"
TogglefOverride();
ReefAngel.PWM.SetChannel(NW1,90);
ReefAngel.PWM.SetChannel(NW2,90);
ReefAngel.PWM.SetChannel(NW3,90);
ReefAngel.PWM.SetChannel(Blue,90);
ReefAngel.PWM.SetChannel(Green,90);
ReefAngel.PWM.SetChannel(Red,90);
ReefAngel.PWM.SetActinic(90);
ReefAngel.PWM.SetDaylight(90);
void MenuEntry7() //"Refuge LEDs"
TogglefOverride();
void MenuEntry8() //"Force Clouds
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry9() //"Storm
ForceLightning=true;
byte x,y;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, 6, 3, "Scott's Reef");
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 14, 131, 14);
//pingSerial();
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp: pH:");
//char text[7];
//ConvertNumToString(text, ReefAngel.Params.PH, 100);
//ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
//ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, x+75, y+18, text);
//pingSerial();
//ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
//pingSerial();
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, x, y, text);
//pingSerial();
/* //Start Moon Phase Display
x += (16*4) + 8;
y += MENU_START_ROW+3;
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, 12, 55, "Moon Phase:");
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawText(20,255,81,55,"Off");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 20) ReefAngel.LCD.DrawText(20,255,81,55,"New");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 35) ReefAngel.LCD.DrawText(20,255,81,55,"Cresent");
else if(ReefAngel.PWM.GetActinicValue() >=35 && ReefAngel.PWM.GetActinicValue() < 45) ReefAngel.LCD.DrawText(20,255,81,55,"Half");
else if(ReefAngel.PWM.GetActinicValue() >=45 && ReefAngel.PWM.GetActinicValue() < 60) ReefAngel.LCD.DrawText(20,255,81,55,"Gibbous");
else if(ReefAngel.PWM.GetActinicValue() >=60 && ReefAngel.PWM.GetActinicValue() < 80) ReefAngel.LCD.DrawText(20,255,81,55,"Full");
//End Display Moon Phase Display*/
ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
//Init and custom menus
AutoTopOff 1
Refuge 2
MHLight 3
Actinic 4
WaveController 5
Heater 6
Fans 7
Pumps 8
//Menu Modes
ReefAngel.FeedingModePorts = B10010000;
ReefAngel.WaterChangePorts = B10010000;
//Pumps and waves on
ReefAngel.Relay.On(Pumps); //Turn Sump/Skimmer on at startup
ReefAngel.Relay.On(WaveController); //Turn WaveController on at startup
ReefAngel.LCD.SetContrast(60); // Set contrast to 60
//Top Off
ReefAngel.StandardATO(AutoTopOff,500); //Setup AutoTopOff as Auto Top-Off function with 500s timeout
//Light Schedule
if ( ! fOverride )
if (hour()>=21 || hour()<10)
ReefAngel.PWM.SetChannel(NW1,PWMParabola(14,0,19,0,15,80,15));
ReefAngel.PWM.SetChannel(NW2,PWMParabola(14,30,19,30,15,90,15));
ReefAngel.PWM.SetChannel(NW3,PWMParabola(15,0,20,0,15,80,15));
ReefAngel.PWM.SetChannel(Blue,PWMParabola(13,30,20,30,15,85,15));
ReefAngel.PWM.SetChannel(Green,PWMParabola(13,30,20,30,15,85,15));
ReefAngel.PWM.SetChannel(Red,PWMParabola(14,0,20,0,15,85,15));
ReefAngel.PWM.SetActinic(PWMParabola(12,00,22,0,15,90,15));
ReefAngel.PWM.SetDaylight(PWMParabola(13,30,20,30,15,95,15));
if ( ! rOverride )
ReefAngel.Relay.On(Refuge);
ReefAngel.Relay.Off(Refuge);
CheckCloud();
//Heating/Cooling
ReefAngel.StandardHeater(Heater,778,782); // Setup Heater to turn on at 77.8F and off at 78.2F
ReefAngel.StandardFan(Fans,780,790); // Setup fans
//Dosing
ReefAngel.DosingPumpRepeat(Port1,0,60,4); // Dose for 4 seconds every 60 minutes with 0 minutes offset
ReefAngel.DosingPumpRepeat(Port2,5,60,4); // Dose for 4 seconds every 60 minutes with 5 minutes offset
ReefAngel.Relay.Write(); // Make relay changes effective
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000111
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000111
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
// lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (ForceLightning)
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
}In the following snippet:
Scott.
