how to: wavemakers off overnight?
bigHUN
Post by bigHUN »
how to code the wavemakers turn on and cycle about the time as the daylight, or similar setting?
I have the main return pump and a closed circuit pump running all time (port8), and the wavemakers on 5-6 may not need to steer overnight?
but again, at feeding time or waterchange time go off as it is now by default.
Re: how to: wavemakers off overnight?
Which port do you have your daylights?
bigHUN
Post by bigHUN »
#define Port6 6 // Wavemaker 2
#define Port5 5 // Wavemaker 1
#define Port4 4 // Standard Lights 2
#define Port3 3 // Standard Lights 1
You can use something like this:
  if (ReefAngel.Relay.Status(Port3))
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
bigHUN
Post by bigHUN »
what that means:
AtilaFinal:136: error: expected unqualified-id before 'if'
AtilaFinal:142: error: expected unqualified-id before 'else'
It's probably that you are trying to place the code above in the wrong place.
Make sure you paste inside the loop() brackets.
