Relay off but still providing power?
Post by image »
Hi,
I just received my Reef Angel yesterday, and this is probably a dumb question, but here goes:
I was able to get everything installed and running, connected up the wifi attachment, and can see everything in the reef angel client. I left my lights as relay 2 (default) and it shows as "Off" in the client, but it's providing power to that outlet. (Just in case I plugged them in wrong, I masked them all to "Off" in the client, but I was still receiving power at the outlet that I believe is relay 2.
I can make relay 8 (my moonlights) work correctly, masking it on and off in the client causes it to turn on and off.
What did I do wrong?
My internal memory:
// Autogenerated file by RAGen (v1.2.1.158), (03/20/2012 05:55)
// Memory_032012_0555.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(8);
    InternalMemory.MHOffHour_write(15);
    InternalMemory.MHDelay_write(5);
    InternalMemory.StdLightsOnHour_write(12);
    InternalMemory.StdLightsOffHour_write(18);
    InternalMemory.StdLightsOffMinute_write(0);
    InternalMemory.ATOTimeout_write(60);
    InternalMemory.ATOHighTimeout_write(60);
    InternalMemory.LEDPWMActinic_write(50);
    InternalMemory.LEDPWMDaylight_write(50);
    InternalMemory.WM1Timer_write(200);
    InternalMemory.WM2Timer_write(354);
    InternalMemory.HeaterTempOn_write(780);
    InternalMemory.HeaterTempOff_write(785);
    InternalMemory.ChillerTempOn_write(790);
    InternalMemory.ChillerTempOff_write(785);
    InternalMemory.RFMode_write(Constant);
    InternalMemory.RFSpeed_write(140);
    InternalMemory.RFDuration_write(8);
    InternalMemory.PWMSlopeEndD_write(128);
    InternalMemory.PWMSlopeEndA_write(128);
    InternalMemory.IMCheck_write(0x5241494D);
    // display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, "   RA code file");
    delay(5000);
My .ino (very simple for now):
// RA_032012_0555.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardFan(Port4);
Re: Relay off but still providing power?
Seems like your box is defective.
You got PM.
