Hi.
JNieuwenhuizen
Hi.
Post by JNieuwenhuizen »
Hi from South Africa everyone.
I will soon be a proud owner of a Reef Angel, and Its time to start looking at the code :?
I have almost no experience with code, except for html.
I see alot of the guys here are really clued-up in coding, at least I'll have some pros helping!
The unit I am getting is :
Reef Angel Head Unit
2 x Relay Boxes
3 x Temperature Probes
Ph Probe
Relay Expansion Module
Salinity Expansion Module + Probe
RF Expansion Module
Wifi Expansion Module
Expansion Hub
I see that there is already developed libraries available , does anyone else have the same setup that did some cool additional things on it?
I think I'll have loads of questions, be patient if you don't mind.. Im a total Noob with this !!!
Re: Hi.
JNieuwenhuizen
Re: Hi.
Nice.
Thank you. I will give it a shot.
JNieuwenhuizen
Re: Hi.
I am as confused as clothes in a tumble dryer.
I have no idea where to start with the code.. Is there anyone that has a simular setup that can hep me with the code?
Re: Hi.
Let's start with just the main unit and we keep adding the other pieces as we go along.
Start here:
http://forum.reefangel.com/viewtopic.php?f=15&t=60
Install the software you will need.
Then, you will go through the internal memory.
And finally you can use RAGen to generate your initial code.
Deckoz2302
Re: Hi.
Post by Deckoz2302 »
I can help what is it you want to accomplish? Most of the things you have will be able to be created via raGEN. Once you have done what Roberto said above me I can help with getting the custom main screen set up .
