Please help me generate a code for all of this.
Ask in here.
Woja222
Post by Woja222 »
Ok, so I'm not as code literate as I thought and the RAgen isn't very clear so some help would be great! I just bought the pwm dimming controller. Here is what I want to do in the end.
Lights:
I want to be able to set the time for whites and actintics to ramp up and down separately on desired times with the ability to set the maximum desired output.
Socket 1:
LED drivers (will have power cut when led dimming circuts go to 0%)
Socket 2:
Main pump
Socket 3:
For a standalone ATO (wont use any of the float switches on the controller)
Socket 4:
Powerhead
Socket 5:
Skimmer
Socket 6:
Drain Water solenoid
Socket 7:
Fill Water solenoid
Socket 8:
Heater
I want a water change setup that will-
Deactivate socket 3 until process is complete
Start with activating socket 6 for a set amount of time then deactivate
After drain is complete activate socket 7 until float switch 1 on the controller is met then deactivate
Reactivate socket 3
I also want float switch 2 to set a high level alarm and deactivate sockets 2, 3, 5, 6, 7, and 8 when it trips.
Also would like to be able to manually override if I wanted to turn on/off any socket temporarily.
Temperate probe for water temperature
Ph probe which I would like to calibrate with 7.0 and 9.0 solution if possible
I would like to be able to connect the controller to the internet via my home router. I have a computer next to the aquarium. An would like to set it up to work through my iphone via the app.
