Help with a code...
Woja222
Help with a code...
Post by Woja222 »
Ok, so I'm not as code literate as I thought and the RAgen isn't very clear so some help would be great! I just bought the pwm dimming controller. Here is what I want to do in the end.
Lights:
I want to be able to set the time for whites and actintics to ramp up and down separately on desired times with the ability to set the maximum desired output.
Socket 1:
LED drivers (will have power cut when led dimming circuts go to 0%)
Socket 2:
Main pump
Socket 3:
For a standalone ATO (wont use any of the float switches on the controller)
Socket 4:
Powerhead
Socket 5:
Skimmer
Socket 6:
Drain Water solenoid
Socket 7:
Fill Water solenoid
Socket 8:
Heater
I want a water change setup that will-
Deactivate socket 3 until process is complete
Start with activating socket 6 for a set amount of time then deactivate
After drain is complete activate socket 7 until float switch 1 on the controller is met then deactivate
Reactivate socket 3
I also want float switch 2 to set a high level alarm and deactivate sockets 2, 3, 5, 6, 7, and 8 when it trips.
Also would like to be able to manually override if I wanted to turn on/off any socket temporarily.
Temperate probe for water temperature
Ph probe which I would like to calibrate with 7.0 and 9.0 solution if possible
I would like to be able to connect the controller to the internet via my home router. I have a computer next to the aquarium. An would like to set it up to work through my iphone via the app.
Re: Help with a code...
Start with this:
Generate an internal memory code and upload to controller.
If you don't know how to, check this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=60
Then use this code:
// Autogenerated file by RAGen (v1.2.1.158), (03/27/2012 08:14)
// RA_032712_0814.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    ReefAngel.FeedingModePorts = Port4Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port5);
    // Specific functions
    ReefAngel.StandardLights(Port1);
    ReefAngel.StandardHeater(Port8);
    ReefAngel.PWM.SetActinic(PWMSlope(9,0,17,0,15,100,60,15));
    ReefAngel.PWM.SetDaylight(PWMSlope(9,0,17,0,15,100,60,15));
      ReefAngel.Relay.Off(Port2);
      ReefAngel.Relay.Off(Port3);
      ReefAngel.Relay.Off(Port5);
      ReefAngel.Relay.Off(Port6);
      ReefAngel.Relay.Off(Port7);
      ReefAngel.Relay.Off(Port8);
    ReefAngel.Portal("Woja222");
Woja222
Post by Woja222 »
Got the internal memory loaded but when I try to upload the RA code you posted it states 'class ReefAngelClass' has no member named'Portal'
Woja222
Post by Woja222 »
By the way, I do not have the wifi attatchment. I planned to leave the reef angel connected to my computer through the usb connection to allow it to connect to the internet. How would I go about setting that up?
Oh, I thought you did..
Remove the Portal() line then.
You won't be able to use the iPhone app without the wifi attachment.
You can however use the Client Suite PC application on your computer and maybe use a remote connection app on the iphone to access the computer.
Just an idea.
Either way, you will want to enable wifi feature. The Client uses the wifi framework to communicate.
So, you need to:
Open RAGen
Move to tab features
Check Mark wifi
Click Save
Then upload the code again.
Woja222
Post by Woja222 »
I tried deleting that line from the code but still came up with an error. Could you generat a new code for me please? The app will no way at all work without the wifi attatchment? The computer hooked to the reef angel is connected directly to my wifi modem.
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
The app can work if you really want to.
You need to find a Serial to TCP application that can be installed on your PC and give it a try.
No one has done it before though.
If you got time to try all the dozens of applications out there to find one that suits us, that would be awesome!!
Woja222
Post by Woja222 »
That code is still coming up with the message error compiling
It's gotta be a different error then.
The Portal line was removed.
Woja222
Post by Woja222 »
p:2053: undefined referance to 'MenuEntry1()'
That's because you enabled Custom Menu feature.
Open RAGen
Go to features tab
Uncheck Custom Menu
Click Save
Woja222
Post by Woja222 »
Now it gave me the message sketch too big...
Use the simple menu feature. Sorry
Woja222
Post by Woja222 »
Still is too big of a sketch. Says 32686 bytes of a 32256 byte maximum
Woja222
Post by Woja222 »
By the way, in the near future I'll probably just end up getting the wifi attatchment so I can easily use the app on my iphone
What features do you have enabled?
You should only have these enabled:
Wifi
Watchdog Timer
Simple Menu
Version Menu
Display LED PWM
If you are using wifi feature, you don't need any of the other ones, unless you have an RA+ board for additional memory.
If you want the other features, you will need to disable wifi.
Woja222
Post by Woja222 »
When will the RA+ board be available? There is a lot of custom writing I would like to do that I feel the opti-boot is going to limit me on.
Pre-order is open.
Should be here in 2 weeks or so.
Woja222
Post by Woja222 »
What is the price of the plus board? I would've rather had the reef angel plus but it wasn't available when I ordered the optiboot. I was lead to believe that the optiboot would've been enough for my functions.
http://www.reefangel.com/Store.ashx
I'm pretty sure you can fit the code you want in the standard RA.
Only if you really want to pack all features should you need the RA+.
Woja222
Post by Woja222 »
Can I get to the part of the code where I can change the upper range of the pH calibration;
For example, I want to change 10 to 9.
Thank you.
It's not a code change.
You have to do the math for simple interpolation.
http://forum.reefangel.com/viewtopic.php?p=7561#p7561
