LED slope question
grafspee1217
LED slope question
Post by grafspee1217 »
I am planning to use the PWM slope to control my LED lights. I did not plan on using an outlet on the relay box as I am using all available sockets for other things. If I set the PWM slope for 15% to 100% for sunrise and 100% to 15% at sunset, does the analog signal go to zero? Theoretically you dont need to turn off the power to the driver just reduce the dimming signal. I am trying to avoid the blinking LED when the signal is to low.
Re: LED slope question
Yes, you can do that.
The best way would be to do this:
ReefAngel.PWM.SetActinic(PWMSlope(10,0,22,0,15,100,60,0);
The last 0 will ensure you get 0 when the it is not time for a slope.
grafspee1217
Thanks!!
