PWM Code Error
JNieuwenhuizen
PWM Code Error
Post by JNieuwenhuizen »
Hi
I need a littlt help.
Some code with a error or 2
  // Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // From Roberto - THANKS ROBERTO!
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  if (hour()>=22 || hour()<8)
      ReefAngel.PWM.SetActinic(MoonPhase());  //Moon phase schedule between 7:00pm - 7:00am
      ActinicPWMValue=PWMSlope(12,00,19,0,0,90,150,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
      //ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
  DaylightPWMValue=PWMSlope(8,00,22,0,0,90,240,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
  CheckCloud();
void CheckCloud()
#define Clouds_Every_5_Days 1
#define Cloud_Chance_per_Day 25
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(11,30)
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,0)
#define Lightning_Change_per_Cloud 25
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(26);
      if ((day()%Clouds_Every_5_Days)!=0) cloudchance=0;
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(36);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
        lightningchance=random(54);
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
The first red line *DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,0,180);* error- Jean2_ino:494: error: 'ReversePWMSlope' was not declared in this scope
The second red line *byte ReversePWMSlope(long cstart,long cend,byte PWMStart,byte PWMEnd, byte clength)* error - Jean2_ino:530: error: a function-definition is not allowed here before '{' token
Last edited by JNieuwenhuizen on Mon Apr 02, 2012 9:51 am, edited 1 time in total.
Re: PWM Code Error
For some reason you also copied formatting.
Towards the end of the code:
Change this:
[color=#FF0000]byte ReversePWMSlope(long cstart,long cend,byte PWMStart,byte PWMEnd, byte clength)[/color]
To this:
The second error, you just need to remove the last } bracket.
