Moonrise/set
jsclownfish
Moonrise/set
Post by jsclownfish »
If I want to have the moon rise and set as the main lights cycle off, I tried this code to increase the moonlight signal up to the current moonphase at 10 pm, stay on over night at monphase levels and to fade away at 7 am. However, it must not be quite right, when I change the times it doesn't sync up. BTW, I have these moonlights connected to the actinic and daylight connections on the relay box.
-Jon
//Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(22,00,7,00,0,MoonPhase(),60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(22,00,7,00,0,MoonPhase(),60,DaylightPWMValue);
Re: Moonrise/set
First note, you will want to get the value before you set the PWM.
   ReefAngel.PWM.SetActinic(ActinicPWMSlope);
I'm not sure how well PWMSlope works crossing over midnight. It may have to be broken into 2 groups with an IF statement:
if ( hour() >= 22 && hour() <= 23 )
   // from 22:00 to 23:59
   ActinicPWMValue=PWMSlope(22,0,23,59,0,MoonPhase(),0,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(22,0,23,59,0,MoonPhase(),0,DaylightPWMValue);
} else if ( hour() >= 0 && hour() < 7 )
   // from 00:00 to 6:59
   ActinicPWMValue=PWMSlope(0,0,7,0,0,MoonPhase(),0,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(0,0,7,0,0,MoonPhase(),0,DaylightPWMValue);
I took out the duration because I'm not quite sure how well it would work in those regards.
This is only a framework / start to solving the problem. More thought will need to be put into it. Bottom line, you will need to do the slope in 2 pieces....1 up to midnight and the other from midnight to your end time. The tricky part is to get the slope working. Maybe this will spark some ideas for you or others.
Re: Moonrise/set
How about this:
Above setup():
byte MoonPWMValue;
Inside loop():
  MoonPWMValue=MoonPhase();
  if (hour()==22 || hour()==6)
     MoonPWMValue=PWMSlope(22,00,7,00,0,MoonPhase(),60,0);
  if (ReefAngel.Relay.Status(Port1)) MoonPWMValue=0;
  ReefAngel.PWM.SetActinic(MoonPWMValue);
  ReefAngel.PWM.SetDaylight(MoonPWMValue);
Just chage the Port1 to whatever port you are using for your main lights.
Basically what the code does is assign MoonPhase() to the MoonPWMValue variable.
If it is time to slope, it will override with the PWMSlope() function.
It main lights are on, it will override with 0.
jsclownfish
Re: Moonrise/set
Thanks! I'll give it a try. I remember now running into this with the idea of gradually slowing down the waves at night. I had problems then with crossing over midnight. http://forum.reefangel.com/viewtopic.ph ... 8&start=30 I think I just ended the slope before midnight. In this case, I thought that would work as well as long as the slope up and down (60 minutes) didn't cross over midnight.
I'll let you know how it goes...
-Jon
Re: Moonrise/set
rimai wrote:How about this:
Above setup():
byte MoonPWMValue;
Inside loop():
Nice. Very simple and concise. That should work great.
JNieuwenhuizen
Re: Moonrise/set
Post by JNieuwenhuizen »
Nice little code Roberto.
I Have a question - if I have no lighs, only PWM channels, how would I change this?
I had this in mind :
  if (hour()==22 || hour()==8)
     MoonPWMValue=PWMSlope(22,0,8,0,0,45,24,MoonPWMValue);
  if (ReefAngel.PWM.Expansion[LEDPWM0]) MoonPWMValue=0;
  ReefAngel.PWM.Expansion[LEDPWM0](MoonPWMValue);
  ReefAngel.PWM.Expansion[LEDPWM1](MoonPWMValue);
  ReefAngel.PWM.Expansion[LEDPWM2](MoonPWMValue);
  ReefAngel.PWM.Expansion[LEDPWM3](MoonPWMValue);
But it does not like - if (ReefAngel.PWM.Expansion[LEDPWM0]) MoonPWMValue=0;
LEDPWM0 will be main lights
Re: Moonrise/set
  if (ReefAngel.PWM.ExpansionChannel[0]) MoonPWMValue=0;
  ReefAngel.PWM.SetChannel(4,MoonPWMValue);
