ato help
Ask in here.
grafxalien
ato help
Post by grafxalien »
I want my ato to check tank the tank water level every hour and then if the tank is low and there is water in the ATO reservoir to then turn on until the tank is at correct level. I want to have a failsafe timer to turn ato off and lock it out if on for over a certain time. Finally, i want to be able to clear the failsafe from the controller or client suite. I think the code has most of it other than the checking every hour instead of continuously check. Also I am not sure of the line to add to a custom menu to put the relay back to auto.
here is the code i found in another thread that should do most of it
  ReefAngel.Init();
  ReefAngel.Timer[1].SetInterval(2);
  if (ReefAngel.HighATO.IsActive() && ReefAngel.LowATO.IsActive())
    ReefAngel.Relay.On(Port1);
    ReefAngel.Timer[1].Start();
  if (!ReefAngel.HighATO.IsActive() && !ReefAngel.LowATO.IsActive())
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Timer[1].ForceTrigger();
  if (bitRead(ReefAngel.Relay.RelayData,Port1-1) && ReefAngel.Timer[1].IsTriggered())
    bitClear(ReefAngel.Relay.RelayMaskOff,Port1-1);
Re: ato help
The singleato function does all that already.
ReefAngel.SingleATO(bool bLow, byte ATORelay, byte byteTimeout, byte byteHrInterval);
You can use like this:
ReefAngel.SingleATO(true, Port1, 60, 1);
The above code will use ATO Low as input port, and Port1 as controlling Port with 60 seconds timeout and it will only run once in every 1 hour.
grafxalien
Re: ato help
would this code placed in loop work correctly? Idea is that it will check to make sure ATO resevoir has water, then run the single low ato code.
Re: ato help
Yeah!!
grafxalien
Re: ato help
well i tried this out today and for some reason the ato pump is stuck on the on position. even after 10 sec it never kicked off. the low ato float is even off, but the pump is still on. any ideas?
full code:
// Autogenerated file by RAGen (v1.2.1.158), (03/28/2012 22:23)
// RA_032812_2223.ino
#define DisplayLEDPWM
#define wifi
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
boolean Actinicauto=true;
boolean Daylightauto=true;
boolean Fullactinic=false;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Force Storm";
prog_char menu2_label[] PROGMEM = "Actinic";
prog_char menu3_label[] PROGMEM = "Daylight";
prog_char menu4_label[] PROGMEM = "Feeding";
prog_char menu5_label[] PROGMEM = "Water Change";
prog_char menu6_label[] PROGMEM = "ATO Clear";
prog_char menu7_label[] PROGMEM = "Overheat Clear";
prog_char menu8_label[] PROGMEM = "pH Calibration";
prog_char menu9_label[] PROGMEM = "Full Actinic";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label, menu9_label  };
void MenuEntry1()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry2()
      if (Actinicauto)
      ActinicPWMValue=0;
      Actinicauto=false;
      ActinicPWMValue+=10;
      if (ActinicPWMValue>100)
          Actinicauto=true;
          ActinicPWMValue=0;
void MenuEntry3()
      if (Daylightauto)
      DaylightPWMValue=0;
      Daylightauto=false;
      DaylightPWMValue+=10;
      if (DaylightPWMValue>100)
          Daylightauto=true;
          DaylightPWMValue=0;
void MenuEntry4()
ReefAngel.FeedingModeStart();
void MenuEntry5()
void MenuEntry6()
ReefAngel.ATOClear();
void MenuEntry7()
ReefAngel.OverheatClear();
void MenuEntry8()
ReefAngel.SetupCalibratePH();
void MenuEntry9()
  if (Fullactinic)
       Daylightauto=true;
       Actinicauto=true;
       Fullactinic=false;
      DaylightPWMValue=0;
      Daylightauto=false;
      ActinicPWMValue=100;
      Actinicauto=false;
      Fullactinic=true;
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port8);
    // Specific functions
  //  ReefAngel.SingleATOLow(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.StandardLights(Port4);
if ((Actinicauto) && (Daylightauto))
    ActinicPWMValue=PWMSlope(10,00,22,15,0,70,120,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(10,00,22,15,0,40,180,DaylightPWMValue);
    CheckCloud();
       ReefAngel.SingleATO(true, Port1, 10, 1);
void CheckCloud()
#define Clouds_Every_X_Days 3
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define End_Cloud_Before NumMins(19,30)
#define Lightning_Change_per_Cloud 50
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
    if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
        //  ActinicPWMValue=100;
          DaylightPWMValue=0;
       //   ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Re: ato help
I think the if statement is causing the issue.
Try this instead:
    if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
