MoonPhase Display
JNieuwenhuizen
MoonPhase Display
Post by JNieuwenhuizen »
Hi.
I am having a bit of a issues with displaying the MoonPhase.
The code I am using does not refer to it specifically, and I have no idea how to get it to look at the values.
  //Start Moon Phase Display
  x += (16*4) + 8;
  y += MENU_START_ROW+3;
  if (ReefAngel.PWM.GetChannelValue(4) ==0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"Off");
  else if(ReefAngel.PWM.GetChannelValue(4) >=1 && ReefAngel.PWM.GetChannelValue(4) < 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"New");
  else if(ReefAngel.PWM.GetChannelValue(4) >=5 && ReefAngel.PWM.GetChannelValue(4) < 10) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"Cresent");
  else if(ReefAngel.PWM.GetChannelValue(4) >=10 && ReefAngel.PWM.GetChannelValue(4) < 20) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"Half");
  else if(ReefAngel.PWM.GetChannelValue(4) >=20 && ReefAngel.PWM.GetChannelValue(4) < 30) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"Gibbous");
  else if(ReefAngel.PWM.GetChannelValue(4) >=30 && ReefAngel.PWM.GetChannelValue(4) < 45) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,81,75,"Full");
  //End Display Moon Phase Display
This does refer to PWM Channel 4, that will be Moonlights. But I cannot define a PWM slope for Moonlights as it goes past 12h00 at night , so using this code to do the MoonPhase
 MoonPWMValue=MoonPhase();
  if (hour()==22 || hour()==6)
    MoonPWMValue=PWMSlope(22,00,6,00,0,MoonPhase(),45,0);
  if (ChannelValue[LEDWhiteBlue]==1) MoonPWMValue=0;
  ReefAngel.PWM.SetChannel(4,MoonPWMValue);
    ChannelValue[LEDWhiteBlue]=PWMSlope(8,0,22,0,0,90,300,ChannelValue[LEDWhiteBlue]);
    ChannelValue[LEDWhiteBlue1]=PWMSlope(8,30,21,30,0,90,270,ChannelValue[LEDWhiteBlue1]);
    ChannelValue[LEDWhiteBlue2]=PWMSlope(9,0,21,0,0,90,240,ChannelValue[LEDWhiteBlue2]);
    ChannelValue[MixedLED]=PWMSlope(12,0,18,0,0,90,60,ChannelValue[MixedLED]);
  //ChannelValue[LEDMoonlights]=PWMSlope(22,0,11,59,0,10,0,ChannelValue[LEDMoonlights]);
  //ChannelValue[LEDMoonlights]=PWMSlope(00,0,7,0,10,45,240,ChannelValue[LEDMoonlights]);
I cannot "GetMoonPWMValue" , as it is not defined on RA_PWMClass
Any help would be appreciated
Re: MoonPhase Display
Just use MoonPhase()
It should give you the correct value to display on screen.
JNieuwenhuizen
Thank You
Now it gives a comiling error : 'class RA_PWM has no member named MoonPhase
Just use MoonPhase() and nothing else.
JNieuwenhuizen
Thank You, Its working now.
One question though, with the pwm functions, what is the diffenece between pwmslope and pwmparabola?
Sebyte
Post by Sebyte »
PWMslope gives a linear rise in the Led %. And PWMparabola gives a bell curve which is more realistic like the way the sun passes through the day.
JNieuwenhuizen
Thank You Sebyte, Will use Parabola rather
