I am new to the reef angel and new to programming at any level. The reef angel is working just fine on the preloaded code, and it appears to communicate with my computer.
However, I cannot currently progress beyond that. I have tried to use RAGen (I have already run RA update utility) to generate the internal memory values .ino file, but when I go to the Arduino program to verify it before uploading, I get an error message saying there was an "error compiling" The pane that shows what is wrong says (and I wish I could cut and paste it) among other related things: "RA_NokiaLCD.cpp
It does not seem to matter whether I am doing the verify while attached to the powered RA. If I am supposed to be hooked to the RA, should the RA be plugged in to power?
