Here's my code:
#define FONT_8X16
#define NUMBERS_8x16
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#include <avr/wdt.h>
byte x,y;
byte hightemp=0;
byte highfloat=0;
byte buzzer=0;
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 23, 2, " Civiello Reef ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
// Display the T1 Temp Value
char text[7];
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
// Display the T2 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Lights");
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display PMW Expansion Channel Headers and % Values
ReefAngel.LCD.Clear(DefaultFGColor,5,43,127,43); // Draw divider
ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,31,48,"LED Dimming");
x=15;
y=58;
ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,DefaultBGColor,x,y,"Day:");
ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,DefaultBGColor,x+24,y,text);
x=75;
y=58;
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,DefaultBGColor,x,y,"Act:");
ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,DefaultBGColor,x+24,y,text);
x=15;
y=68;
for (int a=1;a<5;a++)
if (a>2) x=75;
if (a==3) y=68;
ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x,y,"Ch :");
ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x+12,y,a);
ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x+24,y,text);
y+=10;
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 100, TempRelay);
//Draw Date & Time
ReefAngel.Relay.On(Port8);
ReefAngel.SingleATOLow(Port6); //Setup Port1 as Auto Top-Off function with on/off
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port6); //upper float set as shut off fail safe
//Temp
ReefAngel.StandardHeater(Port5,780,785); // Setup Heater to turn on at 78.0F and off at 78.5F
ReefAngel.StandardHeater(Port4,780,785); // Setup Heater to turn on at 78.0F and off at 78.5F
ReefAngel.StandardFan(Port2,790,785); // Setup Chiller to turn on at 79.0F and off at 78.5F
//Lights
ReefAngel.StandardLights(Port3,21,30,10,30); //Refugium schedule 8:30pm - 10:30am
//Actinics
ReefAngel.PWM.SetActinic(PWMSlope(13,00,19,00,15,25,120,0)); //lights on at 1:00pm off at 7:00pm from 15% to 25% over 120 min
//Day
ReefAngel.PWM.SetDaylight(PWMSlope(13,30,19,30,15,25,120,0)); //lights on at 1:30am off at 7:30pm from 15% to 25% over 120 min
if (ReefAngel.Params.Temp[T1_PROBE]>1500)
ReefAngel.Relay.Off(Port1); //day
ReefAngel.Relay.Off(Port7); //act
hightemp=1;
if (ReefAngel.Params.Temp[T1_PROBE]<1400)
ReefAngel.StandardLights(Port7,12,30,19,30); //Actinic port on at 12:30am of att 7:30pm
ReefAngel.StandardLights(Port1,13,00,20,00); //Daylight port on at 1:00am off at 8:00pm
hightemp=0;
if (ReefAngel.HighATO.IsActive()) highfloat=1; else highfloat=0;
//Buzzer
buzzer=highfloat + hightemp;
if (buzzer>1) buzzer=1;
ReefAngel.PWM.SetChannel(5,buzzer*100);
//Moon
ReefAngel.PWM.SetChannel(1,MoonPhase());
ReefAngel.PWM.SetChannel(2,MoonPhase());
ReefAngel.PWM.SetChannel(3,MoonPhase());
ReefAngel.PWM.SetChannel(4,MoonPhase());
ReefAngel.ShowInterface(); // Draws the standard graphical user interface
