Getting error after no changes.
Ask in here.
tkeracer619
Post by tkeracer619 »
Edit: The code I posted earlier was the wrong one... But I am still having problems with the right one.
I was going to try and get my RF module and Moonlight going today but for whatever reason I cannot get my code to compile.
        #define Actinic             1
        #define T5A                 2
        #define T5B                 3
        #define MH                  4
        #define Autofeeder          5
        #define Blank2              6
        #define FastFlush           7
        #define ReverseOsmosis      8
        byte IOIn[7];
        byte IOIn1[7];
        int Flow0;
        int Flow1;
        int Flow2;
        int Flow01;
        int Flow11;
        int Flow21;
        char text[12];
          ReefAngel.LCD.DrawDate(6, 122);
          ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
          ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
          strcat(text,"  ");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
          ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,4,"CBN:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,15,"GFO:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,26,"BIO:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,4,"GPH");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,15,"GPH");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,26,"GPH");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,37,"DSP:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,48,"BTA:");
          //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,59,"CAL:");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,37,"GPH");
          ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,48,"GPH");
          //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,59,"GPH");
      ConvertNumToString(text, Flow0, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 4, text);
      ConvertNumToString(text, Flow1, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 15, text);
      ConvertNumToString(text, Flow2, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 26, text);
      GetFlow1();
      ConvertNumToString(text, Flow01, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 37, text);
      ConvertNumToString(text, Flow11, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 48, text);
      //ConvertNumToString(text, Flow21, 1);
      //strcat(text,"");
      //ReefAngel.LCD.DrawText(0, 255, 29, 59, text);
          //ReefAngel.LCD.DrawGraph(5, 5);
          ReefAngel.FeedingModePorts = B00000000;
          ReefAngel.WaterChangePorts = B00000000;
          ReefAngel.OverheatShutoffPorts = B00000000;
          ReefAngel.LightsOnPorts = B00000111;
          ReefAngel.StandardLights(Actinic,11,0,24,0);  //Actinic schedule 11:00am - 12:00am
          ReefAngel.StandardLights(T5A,11,30,22,15);  //Blue Plus 1 schedule 11:30am - 11:15pm
          ReefAngel.StandardLights(T5B,11,45,22,30);  //Blue Plus 2 schedule 11:45am - 11:30pm
          ReefAngel.MHLights(MH,12,30,21,15,15);  //Metal Halide schedule 12:30pm - 9:15pm with 15min cool down
          ReefAngel.StandardLights(FastFlush,9,45,9,55);  //RO Fast Flush schedule 9:45am - 9:55pm
          ReefAngel.StandardLights(ReverseOsmosis,9,45,13,0);  //RO Fast Flush schedule 9:45am - 1:00pm
          GetFlow();
          GetFlow1();
          ReefAngel.Portal("tkeracer619");
        void GetFlow()
          Wire.requestFrom(9,7);
          if(Wire.available())
            for (int a=0;a<8;a++)
              IOIn[a]=Wire.read();
          Flow0=(IOIn[1]<<8)+IOIn[2];
          Flow1=(IOIn[3]<<8)+IOIn[4];
          Flow2=(IOIn[5]<<8)+IOIn[6];
        void GetFlow1()
          Wire.requestFrom(10,7);
              IOIn1[a]=Wire.read();
          Flow01=(IOIn1[1]<<8)+IOIn1[2];
          Flow11=(IOIn1[3]<<8)+IOIn1[4];
          Flow21=(IOIn1[5]<<8)+IOIn1[6];
If I delete this line it will compile and upload the code. However, It is not displaying my custom display.
If I don't delete it this is the error code I am getting.
beforeokc.cpp: In function 'void loop()':
beforeokc:127: error: 'class ReefAngelClass' has no member named 'Portal'
Sebyte
Re: Getting error after no changes.
Post by Sebyte »
Have you updated to the latest Dev Libs v0.9.4 and are using the Arduino IDE v1?
If not give it a try.
tkeracer619
I just did the update. No luck :(
tkeracer619
I updated the first post...
Edit:
I messed up my ReefAngel_features.h file. :roll:
I think I have it working again.
Sebyte
Post by Sebyte »
Good stuff! So easy to do.
