Dosing/ Lights
Govertical19
Dosing/ Lights
Post by Govertical19 »
I am trying to setup up dosing pumps on ports 1&2 to run ever hour for 2 secs. What would be the best way to do this? I tried to use the client software and it does not seem to be working.
Would I use a code like this
ReefAngel.DosingPumpRepeat1(Port1,0,360,2);
ReefAngel.DosingPumpRepeat2(Port2,0,360,2);
How would I change it to run ever hour?
Or is there a better way?
Also I am trying to figure out something with my lights I want to change the schedule for the lights I have ports 5&6 set for halides(really standard lights) currently they come on at 11pm and go off at 11 am. But for some reason I can not figure out how I did this.. RAgen so halides going on at 8am and off at 3pm. LOL here is my code. What is telling the lights to go on and off.. Lol
// Autogenerated file by RAGen (v1.2.0.152), (04/10/2012 19:28)
// RA_041012_1928.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    ReefAngel.FeedingModePorts = Port3Bit;
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.DosingPump2(Port1);
    ReefAngel.DosingPump1(Port2);
    ReefAngel.MHLights(Port5);
    ReefAngel.MHLights(Port6);
    ReefAngel.Portal("Govertical19");
    ReefAngel.PWM.SetActinic(PWMSlope(11,0,23,0,15,90,200,0));
    ReefAngel.PWM.SetDaylight(PWMSlope(12,0,22,0,15,40,200,0));
Re: Dosing/ Lights
Yes, very close.
But I'd go with something like this:
  ReefAngel.DosingPumpRepeat(Port1,0,360,2);
  ReefAngel.DosingPumpRepeat(Port2,5,360,2);
The second parameter is offset minutes.
So the 2nd pump pump will work 5 minutes after the 1st. You don't really want to dose at the same time and cause precipitation.
For your lights, you can change the time by using the memory tab of Client or smart phone app.
Govertical19
Re: Dosing/ Lights
Yea, that is what I thought. I did change it in the client in the memory tab but it di not change. I will try thru my phone and see what happens.
With the code you typed in it will run ever hour?
Re: Dosing/ Lights
It runs every 360 minutes for 2 seconds
Govertical19
Re: Dosing/ Lights
ok got it! Thanks!
