This code has exactly the same problem as the code I wrote. The dosing pump doesn't turn off when the appropriate timer should be triggered. I am using timers 3 and 5, with timer 5 set to 1 second and timer 3 set to 600 seconds. It should turn on port8 for one second when the pH drops below 8.00, and then wait 10 minutes, and then reassess the pH and repeat as necessary. But instead, if the pH drops below 8.00, port8 comes on and stays on for a really long time (I'm not sure how long exactly it would stay on, but it stays on for at least 5 or 6 minutes as I have observed it staying on for that long). Here is my code:
boolean dosing=false;
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Timer[1].SetInterval(8);//Wavemaker Timer
ReefAngel.Timer[1].Start();
ReefAngel.Timer[2].SetInterval(8);
ReefAngel.Timer[5].SetInterval(1);//Kalk dosing timer
ReefAngel.Timer[3].SetInterval(600);//Kalk dosing delay timer
ReefAngel.Relay.On(Port4); // Return, Circulation Pump, and Aqualifter
ReefAngel.Relay.On(Port5); // Skimmer
// Initialize and start the RA Client logging timer
ReefAngel.Timer[4].SetInterval(15); // set interval to 15 seconds
ReefAngel.Timer[4].Start();
// Specific functions
ReefAngel.StandardLights(Port1,10,00,20,00); // White Lights
ReefAngel.StandardLights(Port2,9,00,21,00); // Blue Lights
ReefAngel.StandardHeater(Port3,788,792); //Heater
if (ReefAngel.Timer[1].IsTriggered())//Wavemakers' Control
ReefAngel.Timer[2].Start();
ReefAngel.Relay.On(Port6);//Wavemaker 2
if (ReefAngel.Timer[2].IsTriggered())//Wavemakers' Control
ReefAngel.Relay.Off(Port6);
if (ReefAngel.Params.PH<800 && !dosing)
ReefAngel.Timer[5].Start();
ReefAngel.Timer[3].Start();
ReefAngel.Relay.On(Port8);
dosing=true;
if (ReefAngel.Timer[5].IsTriggered())
ReefAngel.Relay.Off(Port8);
if (ReefAngel.Timer[3].IsTriggered())
dosing=false;
// Dump Params
Serial.flush();
Serial.print("<RA><T1>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT1));
Serial.print("</T1><T2>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT2));
Serial.print("</T2><T3>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT3));
Serial.print("</T3><PH>");
Serial.print(ReefAngel.Params.PH);
Serial.print("</PH><R>");
Serial.print(ReefAngel.Relay.RelayData,DEC);
Serial.print("</R><RON>");
Serial.print(ReefAngel.Relay.RelayMaskOn,DEC);
Serial.print("</RON><ROFF>");
Serial.print(ReefAngel.Relay.RelayMaskOff,DEC);
Serial.print("</ROFF></RA>");
Any idea why it won't work?
