I understand the code you posted Roberto, but I don't understand how to implement it with the RA Gen code.
or if you dare, here's the whole first 1/2 of the code (stopped at the setup menu screens function):
* Copyright 2010 Reef Angel / Roberto Imai
* Licensed under the Apache License, Version 2.0 (the "License");
#include "ReefAngel.h"
#include <ReefAngel_Wifi.h>
byte ButtonPress = 0;
SIGNAL(PCINT0_vect) {
if (millis()-ButtonDebounce>600)
ButtonDebounce=millis();
ButtonPress++;
// NOTE for nested menus
// NOTE Menu labels can be a max of 20 characters
// Associate a menu name to a numeric value
// the total number must match the max number of menus
enum Menus {
MainMenu,
SetupMenu,
#ifndef RemoveAllLights
LightsMenu,
#endif // RemoveAllLights
TempsMenu,
#if defined SetupExtras || defined ATOSetup
TimeoutsMenu
#endif // if defined SetupExtras || defined ATOSetup
// Main Menu
prog_char mainmenu_0_label[] PROGMEM = "Feeding";
prog_char mainmenu_1_label[] PROGMEM = "Water Change";
prog_char mainmenu_2_label[] PROGMEM = "Lights ->";
prog_char mainmenu_3_label[] PROGMEM = "Temps ->";
prog_char mainmenu_4_label[] PROGMEM = "Timeouts ->";
prog_char mainmenu_5_label[] PROGMEM = "Setup ->";
#ifdef VersionMenu
prog_char mainmenu_6_label[] PROGMEM = "Version";
#endif // VersionMenu
PROGMEM const char *mainmenu_items[] = {
mainmenu_0_label,
mainmenu_1_label,
mainmenu_2_label,
mainmenu_3_label,
mainmenu_4_label,
mainmenu_5_label,
#ifdef VersionMenu
mainmenu_6_label
enum MainMenuItem {
MainMenu_FeedingMode,
MainMenu_WaterChangeMode,
MainMenu_Lights,
MainMenu_Temps,
MainMenu_Timeouts,
MainMenu_Setup,
#ifdef VersionMenu
MainMenu_Version
// Setup MenuWavemakerSetup
#ifdef WavemakerSetup
prog_char setupmenu_0_label[] PROGMEM = "Wavemaker";
#endif // WavemakerSetup
#ifdef DosingPumpSetup
prog_char setupmenu_1_label[] PROGMEM = "Single Dose";
#endif // DosingPumpSetup
#ifdef DosingPumpIntervalSetup
prog_char setupmenu_2_label[] PROGMEM = "Multi Dose";
#endif // DosingPumpIntervalSetup
prog_char setupmenu_3_label[] PROGMEM = "Calibrate pH";
#ifdef DateTimeSetup
prog_char setupmenu_4_label[] PROGMEM = "Date / Time";
#endif // DateTimeSetup
PROGMEM const char *setupmenu_items[] = {
setupmenu_0_label,
setupmenu_1_label,
setupmenu_2_label,
setupmenu_3_label,
setupmenu_4_label
enum SetupMenuItem {
SetupMenu_Wavemaker,
SetupMenu_DosingPump,
SetupMenu_DosingPumpInterval,
SetupMenu_CalibratePH,
SetupMenu_DateTime
// Lights Menu
prog_char lightsmenu_0_label[] PROGMEM = "Lights On";
prog_char lightsmenu_1_label[] PROGMEM = "Lights Off";
#ifdef MetalHalideSetup
prog_char lightsmenu_2_label[] PROGMEM = "Metal Halides";
prog_char lightsmenu_3_label[] PROGMEM = "MH On Delay";
#endif // MetalHalideSetup
#ifdef StandardLightSetup
prog_char lightsmenu_4_label[] PROGMEM = "Standard Lights";
#endif // StandardLightSetup
#ifdef DisplayLEDPWM
prog_char lightsmenu_5_label[] PROGMEM = "LED PWM";
#endif // DisplayLEDPWM
PROGMEM const char *lightsmenu_items[] = {
lightsmenu_0_label, lightsmenu_1_label,
lightsmenu_2_label,
lightsmenu_3_label,
lightsmenu_4_label,
lightsmenu_5_label
enum LightsMenuItem {
LightsMenu_On,
LightsMenu_Off,
LightsMenu_MetalHalides,
LightsMenu_MetalHalideDelay,
LightsMenu_StandardLights,
LightsMenu_LEDPWM
// Temps Menu
prog_char tempsmenu_0_label[] PROGMEM = "Heater";
prog_char tempsmenu_1_label[] PROGMEM = "Chiller";
#ifdef OverheatSetup
prog_char tempsmenu_2_label[] PROGMEM = "Overheat Set";
#endif // OverheatSetup
prog_char tempsmenu_3_label[] PROGMEM = "Overheat Clear";
PROGMEM const char *tempsmenu_items[] = {
tempsmenu_0_label,
tempsmenu_1_label,
tempsmenu_2_label,
tempsmenu_3_label};
enum TempsMenuItem {
TempsMenu_Heater,
TempsMenu_Chiller,
TempsMenu_Overheat,
TempsMenu_OverheatClr
// Timeouts Menu
#ifdef ATOSetup
prog_char timeoutsmenu_0_label[] PROGMEM = "ATO Set";
#ifdef SingleATOSetup
prog_char timeoutsmenu_1_label[] PROGMEM = "ATO Interval";
#endif // SingleATOSetup
prog_char timeoutsmenu_2_label[] PROGMEM = "ATO Clear";
#endif // ATOSetup
#ifdef SetupExtras
prog_char timeoutsmenu_3_label[] PROGMEM = "Feeding";
prog_char timeoutsmenu_4_label[] PROGMEM = "LCD";
#endif // SetupExtras
PROGMEM const char *timeoutsmenu_items[] = {
#ifdef ATOSetup
timeoutsmenu_0_label,
timeoutsmenu_1_label,
timeoutsmenu_2_label,
#endif // ATOSetup
#ifdef SetupExtras
timeoutsmenu_3_label,
enum TimeoutsMenuItem {
#ifdef ATOSetup
TimeoutsMenu_ATOSet,
TimeoutsMenu_ATOHrInterval,
TimeoutsMenu_ATOClear,
#endif // ATOSetup
#ifdef SetupExtras
TimeoutsMenu_Feeding,
TimeoutsMenu_LCD
ReefAngelClass::ReefAngelClass()
#if defined(__AVR_ATmega2560__)
PCMSK0 |= 128;
#else // __AVR_ATmega2560__
PCMSK0 |= 32;
#endif // __AVR_ATmega2560__
PCICR |= 1;
void ReefAngelClass::Init()
Wire.begin();
Serial.begin(57600);
pinMode(Piezo, OUTPUT);
digitalWrite(lowATOPin,HIGH); //pull up resistor on lowATOPin
digitalWrite(highATOPin,HIGH); //pull up resistor on highATOPin
LCD.Init();
Joystick.Init();
TempSensor.Init();
RAStart=now();
LCD.BacklightOn();
Relay.AllOff();
TODO Check this code, is it needed?
PHMin=EEPROM.read(PH_Min)*256 + EEPROM.read(PH_Min+1);
PHMax=EEPROM.read(PH_Max)*256 + EEPROM.read(PH_Max+1);
PHMin = InternalMemory.PHMin_read();
PHMax = InternalMemory.PHMax_read();
taddr = InternalMemory.T1Pointer_read();
if ((taddr>120) || (taddr<0))
InternalMemory.T1Pointer_write(0);
taddr = 0;
#ifdef SetupExtras
Timer[0].SetInterval(InternalMemory.FeedingTimer_read()); // Default Feeding timer
Timer[3].SetInterval(InternalMemory.LCDTimer_read()); // LCD Sleep Mode timer
#else
Timer[0].SetInterval(900); // Default Feeding timer
Timer[3].SetInterval(600); // LCD Sleep Mode timer
Timer[3].Start(); // start timer
Timer[5].SetInterval(720); // Store Params
Timer[5].ForceTrigger();
// Restore PWM values
PWM.SetActinic(InternalMemory.LEDPWMActinic_read());
PWM.SetDaylight(InternalMemory.LEDPWMDaylight_read());
// Set the default ports to be turned on & off during the 2 modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Default to have ports 4, 5, & 8 toggled
// Override in Setup function of PDE
// Port 87654321
FeedingModePorts = B10011000;
WaterChangePorts = B10011000;
// Set the ports that get shutoff when the overheat value is reached
// Default to have port 3 shutoff
// Port 87654321
OverheatShutoffPorts = B00000100;
#ifdef RelayExp
// Expansion Module ports to toggle, defaults to not toggle any ports
FeedingModePortsE[i] = 0;
WaterChangePortsE[i] = 0;
OverheatShutoffPortsE[i] = 0;
LightsOnPortsE[i] = 0;
#endif // RelayExp
// Set the ports that get turned on when you select the Lights On
// Default to have ports 2 & 3 turn on
// Port 87654321
LightsOnPorts = B00000110;
// Initialize the Nested Menus
InitMenus();
void ReefAngelClass::Refresh()
if (ds.read_bit()==0) return; // ds for OneWire TempSensor
now();
#ifdef DirectTempSensor
LCD.Clear(DefaultBGColor,0,0,1,1);
Params.Temp1=TempSensor.ReadTemperature(TempSensor.addrT1);
Params.Temp2=TempSensor.ReadTemperature(TempSensor.addrT2);
Params.Temp3=TempSensor.ReadTemperature(TempSensor.addrT3);
Params.PH=analogRead(PHPin);
Params.PH=map(Params.PH, PHMin, PHMax, 700, 1000); // apply the calibration to the sensor reading
TempSensor.RequestConvertion();
#else // DirectTempSensor
int x = TempSensor.ReadTemperature(TempSensor.addrT1);
int y;
y = x - Params.Temp1;
// check to make sure the temp readings aren't beyond max allowed
#ifdef DEV_MODE
Serial.print("T1: ");
Serial.print(x);
Serial.print("(");
Serial.print(y);
Serial.print(")");
#endif // DEV_MODE
if ( abs(y) < MAX_TEMP_SWING || Params.Temp1 == 0) Params.Temp1 = x;
x = TempSensor.ReadTemperature(TempSensor.addrT2);
y = x - Params.Temp2;
#ifdef DEV_MODE
Serial.print(", T2: ");
Serial.print(x);
Serial.print("(");
Serial.print(y);
Serial.print(")");
#endif // DEV_MODE
if ( abs(y) < MAX_TEMP_SWING || Params.Temp2 == 0) Params.Temp2 = x;
x = TempSensor.ReadTemperature(TempSensor.addrT3);
y = x - Params.Temp3;
#ifdef DEV_MODE
Serial.print(", T3: ");
Serial.print(x);
Serial.print("(");
Serial.print(y);
Serial.println(")");
#endif // DEV_MODE
if ( abs(y) < MAX_TEMP_SWING || Params.Temp3 == 0) Params.Temp3 = x;
#endif // DirectTempSensor
void ReefAngelClass::SetTemperatureUnit(byte unit)
// 0 (or DEGREE_F) for farenheit
// 1 (or DEGREE_C) for celcius
TempSensor.unit = unit;
void ReefAngelClass::StandardLights(byte LightsRelay, byte OnHour, byte OnMinute, byte OffHour, byte OffMinute)
if (NumMins(OffHour,OffMinute) > NumMins(OnHour,OnMinute))
if (NumMins(hour(),minute()) >= NumMins(OnHour,OnMinute)) Relay.On(LightsRelay); else Relay.Off(LightsRelay);
if (NumMins(hour(),minute()) >= NumMins(OffHour,OffMinute)) Relay.Off(LightsRelay);
if (NumMins(hour(),minute()) >= NumMins(OffHour,OffMinute)) Relay.Off(LightsRelay); else Relay.On(LightsRelay);
void ReefAngelClass::MHLights(byte LightsRelay, byte OnHour, byte OnMinute, byte OffHour, byte OffMinute, byte MHDelay)
unsigned int MHTimer = MHDelay;
MHTimer *= SECS_PER_MIN;
if ( now()-RAStart > MHTimer )
StandardLights(LightsRelay, OnHour, OnMinute, OffHour, OffMinute);
void ReefAngelClass::StandardHeater(byte HeaterRelay, int LowTemp, int HighTemp)
if (Params.Temp1 == 0) return; // Don't turn the heater on if the temp is reading 0
if (Params.Temp1 <= LowTemp && Params.Temp1 > 0) Relay.On(HeaterRelay); // If sensor 1 temperature <= LowTemp - turn on heater
if (Params.Temp1 >= HighTemp) Relay.Off(HeaterRelay); // If sensor 1 temperature >= HighTemp - turn off heater
void ReefAngelClass::StandardFan(byte FanRelay, int LowTemp, int HighTemp)
if (Params.Temp1 >= HighTemp) Relay.On(FanRelay); // If sensor 1 temperature >= HighTemp - turn on fan
if (Params.Temp1 <= LowTemp) Relay.Off(FanRelay); // If sensor 1 temperature <= LowTemp - turn off fan
void ReefAngelClass::StandardATO(byte ATORelay, int ATOTimeout)
// Input: Relay port and timeout value (max number of seconds that ATO pump is allowed to run)
unsigned long TempTimeout = ATOTimeout;
TempTimeout *= 1000;
Is the low switch active (meaning we need to top off) and are we not currently topping off
Then we set the timer to be now and start the topping pump
if ( LowATO.IsActive() && ( !LowATO.IsTopping()) )
LowATO.Timer = millis();
LowATO.StartTopping();
Relay.On(ATORelay);
// If the high switch is activated, this is a safeguard to prevent over running of the top off pump
if ( HighATO.IsActive() )
LowATO.StopTopping(); // stop the low ato timer
Relay.Off(ATORelay);
If the current time minus the start time of the ATO pump is greater than the specified timeout value
AND the ATO pump is currently running:
We turn on the status LED and shut off the ATO pump
This prevents the ATO pump from contniously running.
if ( (millis()-LowATO.Timer > TempTimeout) && LowATO.IsTopping() )
LED.On();
void ReefAngelClass::SingleATO(bool bLow, byte ATORelay, byte byteTimeout, byte byteHrInterval)
// if switch is active, stop the pump because the resevoir is full
// when the switch is not active, we need to turn on the relay to fill up resevoir
bool bCanRun = true;
static int iLastTop = 0;
if ( byteHrInterval )
int iSafeTop = NumMins(hour(), minute()) - iLastTop;
if ( iSafeTop < 0 )
iSafeTop += 1440;
if ( iSafeTop < (byteHrInterval * 60) )
bCanRun = false;
ReefAngel_ATOClass *ato;
if ( bLow )
ato = &LowATO;
ato = &HighATO;
unsigned long t = byteTimeout;
t *= 1000;
if ( ato->IsActive() )
iLastTop = NumMins(hour(), minute());
ato->StopTopping();
else if ( !ato->IsTopping() )
if ( bCanRun )
ato->Timer = millis();
ato->StartTopping();
Relay.On(ATORelay);
if ( (millis() - ato->Timer > t) && ato->IsTopping() )
LED.On();
void ReefAngelClass::DosingPump(byte DPRelay, byte DPTimer, byte OnHour, byte OnMinute, byte RunTime)
This function configures and sets up the dosing pump and turns it on at the appropriate time
Once the timer has expired for the dosing pump, it shuts it off
DPRelay - relay dosing pump is plugged into (0-8)
Timer - timer to control dosing pump
OnHour & OnMinute - time to turn on the dosing pump (in 24hr based time)
RunTime - duration to run the pump
// Let's see if it's supposed to start running the timer now
if ( (NumMins(hour(), minute()) == NumMins(OnHour, OnMinute)) && (second() == 0) )
Relay.On(DPRelay);
//LED.On();
Timer[DPTimer].SetInterval(RunTime);
Timer[DPTimer].Start();
// is the timer expired?
if ( Timer[DPTimer].IsTriggered() )
// timer expired, so let's shut off the pump
Relay.Off(DPRelay);
//LED.Off();
void ReefAngelClass::DosingPumpRepeat(byte DPRelay, byte DPTimer, int RepeatMinute, byte RunTime)
This function runs the specified relay for the RunTime seconds every RepeatMinute minutes.
So you can run the relay for 10 seconds every 60 minutes (1 hour)
This function bases the RepeatMinute off of Midnight (00:00) of the current day. It uses midnight to
compute when the pump will run.
DPRelay - Relay that contains the dosing pump
Timer - number of the timer in the timer array to use
RepeatMinute - number of minutes to wait before running the pump again
RunTime - duration (in seconds) to run the pump
// if the current minutes since midnight are divisible by the repeat interval and the current seconds
// are zero (top of the minute), then we can run the pump
time_t t = now();
uint8_t h = hour(t);
if ( (h == 0) && (minute(t) == 0) )
// if we are at midnight, change hours to 24 so we can get the correct minutes for computation
h = 24;
int current_min = NumMins(h, minute(t));
int r = current_min % RepeatMinute;
if ( (r == 0) && (second(t) == 0) )
Relay.On(DPRelay);
// Should change the timer to be a Dosing Pump Timer
Relay.Off(DPRelay);
void ReefAngelClass::Wavemaker(byte WMRelay, byte WMTimer)
// TODO Update Timers appropriately
if ( Timer[WMTimer].IsTriggered() )
Timer[WMTimer].Start();
Relay.Toggle(WMRelay);
// Simplified for PDE file
void ReefAngelClass::StandardLights(byte Relay)
StandardLights(Relay,
InternalMemory.StdLightsOnHour_read(),
InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(),
InternalMemory.StdLightsOffMinute_read());
void ReefAngelClass::MHLights(byte Relay)
MHLights(Relay,
InternalMemory.MHOnHour_read(),
InternalMemory.MHOnMinute_read(),
InternalMemory.MHOffHour_read(),
InternalMemory.MHOffMinute_read(),
InternalMemory.MHDelay_read());
void ReefAngelClass::StandardHeater(byte Relay)
StandardHeater(Relay,
InternalMemory.HeaterTempOn_read(),
InternalMemory.HeaterTempOff_read());
void ReefAngelClass::StandardFan(byte Relay)
StandardFan(Relay,
InternalMemory.ChillerTempOff_read(),
InternalMemory.ChillerTempOn_read());
void ReefAngelClass::StandardATO(byte Relay)
StandardATO(Relay, InternalMemory.ATOTimeout_read());
void ReefAngelClass::SingleATOLow(byte Relay)
SingleATO(true, Relay, InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
void ReefAngelClass::SingleATOHigh(byte Relay)
SingleATO(false, Relay, InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
void ReefAngelClass::DosingPump1(byte Relay)
DosingPump(Relay, 1,
InternalMemory.DP1OnHour_read(),
InternalMemory.DP1OnMinute_read(),
InternalMemory.DP1Timer_read());
void ReefAngelClass::DosingPump2(byte Relay)
DosingPump(Relay, 2,
InternalMemory.DP2OnHour_read(),
InternalMemory.DP2OnMinute_read(),
InternalMemory.DP2Timer_read());
void ReefAngelClass::DosingPumpRepeat1(byte Relay)
DosingPumpRepeat(Relay, 1,
InternalMemory.DP1RepeatInterval_read(),
void ReefAngelClass::DosingPumpRepeat2(byte Relay)
DosingPumpRepeat(Relay, 2,
InternalMemory.DP2RepeatInterval_read(),
void ReefAngelClass::Wavemaker1(byte WMRelay)
static bool bSetup = false;
if ( ! bSetup )
Timer[1].SetInterval(InternalMemory.WM1Timer_read());
Timer[1].Start();
Relay.On(WMRelay);
WM1Port = WMRelay;
// once setup, don't setup again
bSetup = true;
Wavemaker(WMRelay, 1);
void ReefAngelClass::Wavemaker2(byte WMRelay)
if ( ! bSetup )
Timer[2].SetInterval(InternalMemory.WM2Timer_read());
Timer[2].Start();
Relay.On(WMRelay);
WM2Port = WMRelay;
#endif // Wavemakersetup
bSetup = true;
Wavemaker(WMRelay, 2);
#ifdef VersionMenu
void ReefAngelClass::DisplayVersion()
// Display the Software Version
LCD.DrawText(ModeScreenColor,DefaultBGColor,10,10,"Reef Angel");
LCD.DrawText(ModeScreenColor,DefaultBGColor,10,20,"v"ReefAngel_Version);
#ifdef DEV_MODE
LCD.DrawText(ModeScreenColor,DefaultBGColor,10,30,"Dev Mode");
#endif // DEV_MODE
#ifdef wifi
// Display wifi related information
// Place holder information currently, need wifi module
// to be able to write functions to retrieve actual information
LCD.DrawText(ModeScreenColor,DefaultBGColor,10,40,"Wifi Enabled");
#endif // wifi
void ReefAngelClass::ClearScreen(byte Color)
// clears the entire screen
LCD.Clear(Color, 0, 0, 131, 131);
void ReefAngelClass::MoonlightPWM(byte RelayID, bool ShowPWM)
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m = month();
d = day();
y = year();
yy = y - ((12-m)/10);
mm = m + 9;
if (mm>=12) mm -= 12;
K1 = 365.25 * (yy+4712);
K2 = 30.6 * mm+.5;
J = K1+K2+d+59-K3;
V -= int(V/100)*100;
V = abs(V-50);
PWMvalue = 4*abs(50-V); // 5.12=100% 4=~80%
pinMode(lowATOPin,OUTPUT);
if (RelayID && (bitRead(Relay.RelayData,RelayID-1)==0)) PWMvalue=0;
analogWrite(lowATOPin,PWMvalue);
if (ShowPWM) PWM.SetActinic((PWMvalue*100)/255);
void ReefAngelClass::PCLogging()
// This function is used for logging the data to Dave's PC Client software
// It prints the strings from program memory instead of RAM
PROGMEMprint(XML_T1);
Serial.print(Params.Temp1);
PROGMEMprint(XML_T2);
Serial.print(Params.Temp2);
PROGMEMprint(XML_T3);
Serial.print(Params.Temp3);
PROGMEMprint(XML_PH);
Serial.print(Params.PH);
PROGMEMprint(XML_R);
Serial.print(Relay.RelayData,DEC);
PROGMEMprint(XML_RON);
Serial.print(Relay.RelayMaskOn,DEC);
PROGMEMprint(XML_ROFF);
Serial.print(Relay.RelayMaskOff,DEC);
PROGMEMprint(XML_RE_CLOSE);
PROGMEMprint(XML_RE_OFF);
Serial.print(">");
#ifdef RelayExp
for ( int EID = 0; EID < MAX_RELAY_EXPANSION_MODULES; EID++ )
// relay data
PROGMEMprint(XML_RE_OPEN);
Serial.print(EID, DEC);
Serial.print(">");
Serial.print(Relay.RelayDataE[EID],DEC);
Serial.print(">");
// relay on mask
PROGMEMprint(XML_RE_ON);
Serial.print(">");
Serial.print(Relay.RelayMaskOnE[EID],DEC);
Serial.print(">");
// relay off mask
Serial.print(">");
Serial.print(Relay.RelayMaskOffE[EID],DEC);
Serial.print(">");
#endif // RelayExp
PROGMEMprint(XML_ATOLOW);
Serial.print(LowATO.IsActive());
PROGMEMprint(XML_ATOHIGH);
Serial.print(HighATO.IsActive());
PROGMEMprint(XML_END);
#ifdef wifi
void ReefAngelClass::LoadWebBanner(int pointer, byte qty)
webbannerpointer = pointer;
webbannerqty = qty;
void ReefAngelClass::WebBanner()
char buffer[22];
int ptr = webbannerpointer;
int tagptr = pgm_read_word(&(webbanner_tags[0]));
PROGMEMprint(BannerGET);
Serial.print(Params.Temp1, DEC);
PROGMEMprint(BannerT2);
Serial.print(Params.Temp2, DEC);
PROGMEMprint(BannerT3);
Serial.print(Params.Temp3, DEC);
PROGMEMprint(BannerPH);
Serial.print(Params.PH, DEC);
PROGMEMprint(BannerRelayData);
// compute the correct relay data, when we force a port on or off, it does not get reflected in the relaydata
// so we must compute it based on the mask and send the data to the banner (compute just like when sending the
// relay data on the wire)
byte TempRelay = Relay.RelayData;
TempRelay &= Relay.RelayMaskOff;
TempRelay |= Relay.RelayMaskOn;
Serial.print(TempRelay, DEC);
if ( webbannerqty == WEB_BANNER_QTY )
for ( int i = 0; i < WEB_BANNER_QTY; i++ )
strcpy_P(buffer, (char *)tagptr++);
tagptr += strlen(buffer);
Serial.print("&");
Serial.print(buffer);
Serial.print("=");
strcpy_P(buffer, (char *)ptr++);
} // for i
Serial.print("&");
Serial.print("=");
Serial.print("&");
P(badmsg)=BAD;
printP(badmsg);
Serial.println("\n\n");
#endif // wifi
void ReefAngelClass::InitMenus()
// loads all the menus
menusptr[MainMenu] = pgm_read_word(&(mainmenu_items[0]));
menuqtysptr[MainMenu] = SIZE(mainmenu_items);
menusptr[SetupMenu] = pgm_read_word(&(setupmenu_items[0]));
menuqtysptr[SetupMenu] = SIZE(setupmenu_items);
menusptr[LightsMenu] = pgm_read_word(&(lightsmenu_items[0]));
menuqtysptr[LightsMenu] = SIZE(lightsmenu_items);
menusptr[TempsMenu] = pgm_read_word(&(tempsmenu_items[0]));
menuqtysptr[TempsMenu] = SIZE(tempsmenu_items);
menusptr[TimeoutsMenu] = pgm_read_word(&(timeoutsmenu_items[0]));
menuqtysptr[TimeoutsMenu] = SIZE(timeoutsmenu_items);
// initialize menus
PreviousMenu = DEFAULT_MENU;
DisplayedMenu = DEFAULT_MENU; // default menu to display
SelectedMenuItem = DEFAULT_MENU_ITEM; // default item to have selected
redrawmenu = true;
showmenu = false; // initially we are showing the main graphic and no menu
void ReefAngelClass::ShowInterface()
Refresh();
// are we displaying the menu or not??
if ( showmenu )
DisplayMenuHeading();
DisplayMenu();
// not displaying the menu, so we're gonna show the default screen
if ( DisplayedMenu == DEFAULT_MENU )
// process screensaver timeout
if ( Timer[3].IsTriggered() )
// Screensaver timeout expired
LCD.BacklightOff();
if ( Joystick.IsButtonPressed() )
// turn the backlight on
LCD.BacklightOn();
// TODO check Timer[3] code
if ( Timer[3].Trigger == 0 )
Timer[3].Start();
return;
// Clears the screen to draw the menu
// Displays main menu, select first item, save existing menu
ClearScreen(DefaultBGColor);
DisplayedMenu = MAIN_MENU;
showmenu = true;
redrawmenu = true;
menutimeout = now();
// get out of this function and display the menu
return;
if ( Joystick.IsUp() || Joystick.IsDown() || Joystick.IsRight() || Joystick.IsLeft() )
// Turn backlight on
LCD.BacklightOn();
Timer[3].Start();
// display everything on the home screen except the graph
// the graph is drawn/updated when we exit the main menu & when the parameters are saved
LCD.DrawDate(6, 112);
LCD.DrawMonitor(15, 60, Params, PWM.GetDaylightValue(), PWM.GetActinicValue());
LCD.DrawMonitor(15, 60, Params);
LCD.DrawOutletBox(12, 93, TempRelay);
// Process any checks/tests/events that can happen while displaying the home screen
// This can be the timers for wavemakers or any overheat temperatures
// process timers
if ( Timer[5].IsTriggered() )
int CurTemp;
// Values are stored in the I2CEEPROM1
taddr++;
if ( taddr >= 120 ) taddr = 0;
Timer[5].Start();
CurTemp = map(Params.Temp1, T1LOW, T1HIGH, 0, 50); // apply the calibration to the sensor reading
CurTemp = constrain(CurTemp, 0, 50); // in case the sensor value is outside the range seen during calibration
//LCD.Clear(DefaultBGColor,0,0,1,1);
Memory.Write(taddr, CurTemp);
CurTemp = map(Params.Temp2, T2LOW, T2HIGH, 0, 50); // apply the calibration to the sensor reading
Memory.Write(taddr+120, CurTemp);
CurTemp = map(Params.Temp3, T3LOW, T3HIGH, 0, 50); // apply the calibration to the sensor reading
Memory.Write(taddr+240, CurTemp);
CurTemp = map(Params.PH, PHLOW, PHHIGH, 0, 50); // apply the calibration to the sensor reading
Memory.Write(taddr+360, CurTemp);
if ((taddr%10)==0) InternalMemory.T1Pointer_write(taddr);
LCD.DrawGraph(5, 5);
// if temp2 exceeds overheat temp
if ( Params.Temp2 >= InternalMemory.OverheatTemp_read() )
#else // OverheatSetup
if ( Params.Temp2 >= 1500 ) // 150.0 F is the default
LED.On();
// invert the ports that are activated
Relay.RelayMaskOff = ~OverheatShutoffPorts;
#ifdef RelayExp
Relay.RelayMaskOffE[i] = ~OverheatShutoffPortsE[i];
#endif // RelayExp
// commit relay changes
Relay.Write();
// we are viewing another screen
// button is pressed, so we gotta exit out, show the menu & redraw it too
redrawmenu = true;
showmenu = true;
Timer[0].ForceTrigger();
Timer[3].Start();
} // if DisplayedMenu == DEFAULT_MENU
} // if showmenu
void ReefAngelClass::DisplayMenu()
// redrawmenu should only get set from within this function when we move the joystick or press the button
byte qty = menuqtysptr[DisplayedMenu];
int ptr = menusptr[DisplayedMenu];
if ( Joystick.IsUp() )
// process UP press
if ( (--SelectedMenuItem) > qty )
// we're moving up and we hit the top of the list
// gotta wrap down to the bottom of the list
// qty - 1 gives us the last item in our list
//SelectedMenuItem = qty - 1;
// This allows us to add in our last item
SelectedMenuItem = qty;
redrawmenu = true;
if ( Joystick.IsDown() )
// process DOWN press
// > allows for selection of last item, >= skips it
if ( (++SelectedMenuItem) > qty )
// we've hit the bottom of the list
// wrap around to the top of the list
redrawmenu = true;
// TODO Have ability to customize menu timeout delay
if ( (now() - menutimeout) > MENU_TIMEOUT )
// menu timeout returns to the main screen
// skip all the other menu checks
SelectedMenuItem = EXCEED_TIMEOUT_MENU;
DisplayedMenu = EXCEED_TIMEOUT_MENU;
ButtonPress++;
// button gets pressed, so we need to handle the button press
ProcessButtonPress();
redrawmenu = true;
// Don't finish processing the rest of the menu
return;
// don't redraw the menu if we don't have to
if ( ! redrawmenu )
return;
byte i;
byte bcolor, fcolor;
char buffer[22];
for ( i = 0; i <= qty; i++ )
bcolor = DefaultBGColor;
fcolor = DefaultFGColor;
if ( i < qty )
// the last item in the list is either Exit or Prev Menu
if ( DisplayedMenu == MainMenu )
strcpy(buffer, "Exit");
strcpy(buffer, "<- Prev Menu");
// change the background color on the selected menu entry
if ( i == SelectedMenuItem )
bcolor = SelectionBGColor;
fcolor = SelectionFGColor;
LCD.Clear(bcolor, MENU_START_COL-3,
(i*MENU_START_ROW)+MENU_HEADING_SIZE-1,
MENU_END_COL,
(i*MENU_START_ROW)+(MENU_HEADING_SIZE+MENU_ITEM_HEIGHT-1));
LCD.DrawText(fcolor, bcolor, MENU_START_COL, (i*MENU_START_ROW)+MENU_HEADING_SIZE, buffer);
} // for i
// once drawn, no need to redraw yet
redrawmenu = false;
void ReefAngelClass::DisplayMenuHeading()
// NOTE do we redraw the menu heading or not? use same logic as with the menu
if ( ! redrawmenu )
return;
char buffer[10];
switch ( DisplayedMenu )
default:
// //strcpy(buffer, "Menu:");
// sprintf(buffer, "Menu (%d):", MenuNum);
// break;
case MainMenu:
strcpy(buffer, "Main:");
break;
case SetupMenu:
strcpy(buffer, "Setup:");
break;
case LightsMenu:
strcpy(buffer, "Lights:");
break;
case TempsMenu:
strcpy(buffer, "Temp:");
break;
case TimeoutsMenu:
strcpy(buffer, "Timeouts:");
break;
} // switch MenuNum
// clear the line that has the menu heading on it
LCD.Clear(DefaultBGColor, MENU_START_COL, MENU_START_ROW, MAX_X, MAX_Y);
// Display the menu heading
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, buffer);
void ReefAngelClass::DisplayMenuEntry(char *text)
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, text);
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW*4, "Press to exit...");
void ReefAngelClass::FeedingMode()
LCD.DrawText(ModeScreenColor, DefaultBGColor, 30, 10, "Feeding Mode");
Timer[0].Start(); //Start Feeding Mode timer
#ifdef DisplayImages
LCD.DrawEEPromImage(40,50, 40, 30, I2CEEPROM2, I2CEEPROM2_Feeding);
#endif // DisplayImages
int t;
bool bDone = false;
do
t = Timer[0].Trigger - now();
if ( (t >= 0) && ! Timer[0].IsTriggered() )
LCD.Clear(DefaultBGColor,60+(intlength(t)*5),100,100,108);
LCD.DrawText(DefaultFGColor,DefaultBGColor,60,100,t);
bDone = true;
// joystick button pressed, so we stop the feeding mode
bDone = true;
delay(200);
} while ( ! bDone );
// we're finished, so let's clear the screen and return
Timer[3].Start(); // start LCD shutoff timer
void ReefAngelClass::WaterChangeMode()
LCD.DrawText(ModeScreenColor, DefaultBGColor, 20, 10, "Water Change Mode");
LCD.DrawEEPromImage(51,55, 40, 30, I2CEEPROM2, I2CEEPROM2_Water_Change);
do
// just wait for the button to be pressed
delay(200);
} while ( ! Joystick.IsButtonPressed() );
void ReefAngelClass::ProcessButtonPress()
bool bResetMenuTimeout = true;
default: // DEFAULT_MENU == 255
// // Default Screen
break;
case MainMenu:
ProcessButtonPressMain();
break;
case SetupMenu:
ProcessButtonPressSetup();
break;
case LightsMenu:
ProcessButtonPressLights();
break;
case TempsMenu:
ProcessButtonPressTemps();
break;
case TimeoutsMenu:
ProcessButtonPressTimeouts();
break;
case EXCEED_TIMEOUT_MENU:
// we bypass all the other menus when the timeout has exceeded
// we need to mimic the default action for the main menu in addition to
// clearing out the stack
showmenu = false;
bResetMenuTimeout = false;
// we are exiting the menu, so draw the graph
LCD.DrawGraph(5, 5); // Redraw graphic of params
break;
// if a button was pressed, we have to reset the timeout after processing the press
if ( bResetMenuTimeout )
void ReefAngelClass::ProcessButtonPressMain()
showmenu = true;
switch ( SelectedMenuItem )
case MainMenu_FeedingMode:
// turn off ports
#ifdef SaveRelayState
// TODO Test SaveRelayState
byte CurrentRelayState = Relay.RelayData;
#endif // SaveRelayState
Relay.RelayMaskOff = ~FeedingModePorts;
#ifdef RelayExp
byte i;
for ( i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
Relay.RelayMaskOffE[i] = ~FeedingModePortsE[i];
#endif // RelayExp
Relay.Write();
// run feeding mode
FeedingMode();
// turn on ports
Relay.RelayMaskOff = B11111111;
#ifdef RelayExp
Relay.RelayMaskOffE[i] = B11111111;
#endif // RelayExp
// restore ports
Relay.RelayData = CurrentRelayState;
Relay.Write();
break;
case MainMenu_WaterChangeMode:
// turn off ports
Relay.RelayMaskOff = ~WaterChangePorts;
#ifdef RelayExp
byte i;
Relay.RelayMaskOffE[i] = ~WaterChangePortsE[i];
#endif // RelayExp
Relay.Write();
// Display the water change mode
WaterChangeMode();
// turn on ports
#ifdef RelayExp
#endif // RelayExp
Relay.Write();
break;
case MainMenu_Lights:
PreviousMenu = DisplayedMenu;
DisplayedMenu = LightsMenu;
break;
case MainMenu_Temps:
DisplayedMenu = TempsMenu;
break;
case MainMenu_Timeouts:
DisplayedMenu = TimeoutsMenu;
break;
case MainMenu_Setup:
DisplayedMenu = SetupMenu;
break;
#ifdef VersionMenu
case MainMenu_Version:
DisplayVersion();
// turn off the menu so we can wait for the button press to exit
showmenu = false;
break;
default:
// This will be the EXIT choice
// switch to the previous menu
// disable the menu, display main screen
showmenu = false;
// When we exit the main menu, we will redraw the graph
break;
void ReefAngelClass::ProcessButtonPressSetup()
showmenu = true;
case SetupMenu_Wavemaker:
int v = InternalMemory.WM1Timer_read();
int y = InternalMemory.WM2Timer_read();
if ( SetupOption(v, y, 0, 21600, 5, "s", "", "Setup Wavemakers", "WM1:", "WM2:") )
InternalMemory.WM1Timer_write(v);
InternalMemory.WM2Timer_write(y);
// after we set the values we need to update the timers
Timer[1].Trigger = 0;
Timer[1].SetInterval(v);
Timer[1].Start();
Relay.On(WM1Port);
Timer[2].Trigger = 0;
Timer[2].SetInterval(y);
Timer[2].Start();
Relay.On(WM2Port);
Relay.Write();
break;
case SetupMenu_DosingPump:
SetupDosingPump();
break;
case SetupMenu_DosingPumpInterval:
int v = InternalMemory.DP1RepeatInterval_read();
int y = InternalMemory.DP2RepeatInterval_read();
if ( SetupOption(v, y, 1, 1440, 4, "m", "", "Repeat Interval", "DP1:", "DP2:") )
InternalMemory.DP1RepeatInterval_write(v);
InternalMemory.DP2RepeatInterval_write(y);
v = InternalMemory.DP1Timer_read();
y = InternalMemory.DP2Timer_read();
if ( SetupOption(v, y, 1, 255, 3, "s", "", "Run Time", "DP1:", "DP2:") )
InternalMemory.DP1Timer_write(v);
InternalMemory.DP2Timer_write(y);
break;
case SetupMenu_CalibratePH:
SetupCalibratePH();
break;
case SetupMenu_DateTime:
SetupDateTime();
break;
default:
DisplayedMenu = PreviousMenu;
break;
void ReefAngelClass::ProcessButtonPressLights()
showmenu = true; // set to true when displaying setup screens
case LightsMenu_On:
// turn on ports
Relay.RelayMaskOn = LightsOnPorts;
#ifdef RelayExp
Relay.RelayMaskOnE[i] = LightsOnPortsE[i];
#endif // RelayExp
Relay.Write();
DisplayMenuEntry("Lights On");
showmenu = false;
break;
case LightsMenu_Off:
// reset ports
Relay.RelayMaskOn = B00000000;
#ifdef RelayExp
Relay.RelayMaskOnE[i] = B00000000;
#endif // RelayExp
// sets PWM to 0%
PWM.SetActinic(0);
PWM.SetDaylight(0);
Relay.Write();
DisplayMenuEntry("Restore Lights");
showmenu = false;
break;
case LightsMenu_MetalHalides:
SetupLightsOptionDisplay(true);
break;
case LightsMenu_MetalHalideDelay:
int v = InternalMemory.MHDelay_read();
int y = -1;
if ( SetupOption(v, y, 0, 255, 3, "m", "", "Setup MH Delay", "", "") )
InternalMemory.MHDelay_write((uint8_t)v);
break;
case LightsMenu_StandardLights:
SetupLightsOptionDisplay(false);
break;
case LightsMenu_LEDPWM:
int v = InternalMemory.LEDPWMActinic_read();
int y = InternalMemory.LEDPWMDaylight_read();
if ( SetupOption(v, y, 0, 100, 3, "%", "", "Setup LED", "AP:", "DP:") )
InternalMemory.LEDPWMActinic_write((uint8_t)v);
InternalMemory.LEDPWMDaylight_write((uint8_t)y);
PWM.SetActinic((uint8_t)v);
PWM.SetDaylight((uint8_t)y);
break;
default:
break;
void ReefAngelClass::ProcessButtonPressTemps()
showmenu = true;
case TempsMenu_Heater:
int v = InternalMemory.HeaterTempOn_read();
int y = InternalMemory.HeaterTempOff_read();
if ( SetupOption(v, y, 700, 900, 3, "F", ".", "Setup Heater", "On @", "Off @") )
InternalMemory.HeaterTempOn_write(v);
InternalMemory.HeaterTempOff_write(y);
break;
case TempsMenu_Chiller:
int v = InternalMemory.ChillerTempOn_read();
int y = InternalMemory.ChillerTempOff_read();
if ( SetupOption(v, y, 700, 900, 3, "F", ".", "Setup Chiller", "On @", "Off @") )
InternalMemory.ChillerTempOn_write(v);
InternalMemory.ChillerTempOff_write(y);
break;
case TempsMenu_Overheat:
int v = InternalMemory.OverheatTemp_read();
int y = -1;
if ( SetupOption(v, y, 800, 2000, 4, "F", ".", "Setup Overheat", "", "") )
InternalMemory.OverheatTemp_write(v);
break;
case TempsMenu_OverheatClr:
LED.Off();
#ifdef RelayExp
#endif // RelayExp
Relay.Write();
DisplayMenuEntry("Clear Overheat");
showmenu = false;
break;
default:
break;
void ReefAngelClass::ProcessButtonPressTimeouts()
showmenu = true;
#ifdef ATOSetup
case TimeoutsMenu_ATOSet:
int v = InternalMemory.ATOTimeout_read();
int y = InternalMemory.ATOHighTimeout_read();
if ( SetupOption(v, y, 0, 255, 3, "s", "", "ATO Timeout", "Low:", "High:") )
InternalMemory.ATOTimeout_write((uint8_t)v);
InternalMemory.ATOHighTimeout_write((uint8_t)y);
#else // SingleATOSetup
int y = -1;
if ( SetupOption(v, y, 0, 255, 3, "s", "", "ATO Timeout", "", "") )
break;
case TimeoutsMenu_ATOHrInterval:
int v = InternalMemory.ATOHourInterval_read();
int y = InternalMemory.ATOHighHourInterval_read();
if ( SetupOption(v, y, 0, 24, 2, "h", "", "ATO Interval", "Low:", "High:") )
InternalMemory.ATOHourInterval_write((uint8_t)v);
InternalMemory.ATOHighHourInterval_write((uint8_t)y);
break;
case TimeoutsMenu_ATOClear:
// Need delay for clearing & returning screen
LED.Off();
HighATO.StopTopping();
DisplayMenuEntry("Clear ATO Timeout");
showmenu = false;
break;
#endif // ATOSetup
#ifdef SetupExtras
case TimeoutsMenu_Feeding:
int v = InternalMemory.FeedingTimer_read();
int y = -1;
if ( SetupOption(v, y, 0, 3600, 4, "s", "", "Feeding Timer", "", "") )
InternalMemory.FeedingTimer_write(v);
// update the feeding timer value
Timer[0].SetInterval(v);
break;
case TimeoutsMenu_LCD:
int v = InternalMemory.LCDTimer_read();
int y = -1;
if ( SetupOption(v, y, 0, 3600, 4, "s", "", "Screen Timeout", "" "") )
InternalMemory.LCDTimer_write(v);
// update the timer value
Timer[3].SetInterval(v);
Timer[3].Start();
break;
default:
break;
