Additionally, most of my menu functions are not working, such as 8 and 9. They seem to immediately exit back to the main display when I select them.
// Autogenerated file by RAGen (v1.2.2.171), (05/05/2012 12:46)
// RA_050512_1246.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 0
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.On(Box1_Port8);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Box1_Port8);
ReefAngel.LCD.DrawDate(6, 119);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
#endif // RelayExp
// Change the 45 to adjust the horizontal position of the text
ReefAngel.LCD.DrawGraph(5, 5);
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port8Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port4);
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
ReefAngel.StandardLights(Port1,23,0,2,0); // Moon lights on 23:00-02:00
ReefAngel.StandardHeater(Port2,780,790); // 800w heater on at 78.0, off at 79.0
ReefAngel.MHLights(Port4,14,0,22,0,15); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardATO(Port5,120); // Standard ATO with 120s timeout
ReefAngel.StandardATO(Port6,120); // Standard ATO with 120s timeout
ReefAngel.StandardLights(Port7,21,0,13,0); // Sump lights on 21:00-13:00
ReefAngel.MHLights(Box1_Port1,14,0,22,0,15); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardHeater(Box1_Port2,785,790); // 250w heater on at 78.5, off at 79.0
ReefAngel.StandardLights(Box1_Port3,13,0,23,0); // Actinics on 13:00-23:00
ReefAngel.StandardATO(Box1_Port5,120); // Standard ATO with 120s timeout
ReefAngel.DosingPumpRepeat(Box1_Port6,0,480,30); //Dose for 30s every 480m, 0m offset
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("btorrenga");
