Compiling error, of course
jason
Post by jason »
Hi ,
I have installed all the softwares (Arduino RA, then RAGEN), then did the update of the libraries.
I am trying to upload the initial memory settings, but i keep getting compile errors.....
I assume they are all the latest, as I downloaded them today.
ArduinoRA is version 1
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\InitialInternalMemory.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\InitialInternalMemory.cpp.o
In file included from InitialInternalMemory.cpp:2:
D:\Documents\Arduino\libraries\Globals/Globals.h:35: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Globals/Globals.h:36: warning: only initialized variables can be placed into program memory area
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory -ID:\Documents\Arduino\libraries\Globals\utility D:\Documents\Arduino\libraries\Globals\Globals.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\Globals\Globals.cpp.o
In file included from D:\Documents\Arduino\libraries\Globals\Globals.cpp:22:
D:\Documents\Arduino\libraries\Globals\/Globals.h:35: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Globals\/Globals.h:36: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Globals\Globals.cpp: In function 'void ConvertNumToString(char*, int, byte)':
D:\Documents\Arduino\libraries\Globals\Globals.cpp:123: warning: comparison between signed and unsigned integer expressions
D:\Documents\Arduino\libraries\Globals\Globals.cpp: In function 'byte intlength(int)':
D:\Documents\Arduino\libraries\Globals\Globals.cpp:32: warning: control reaches end of non-void function
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory -ID:\Documents\Arduino\libraries\Time\utility D:\Documents\Arduino\libraries\Time\DateStrings.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\Time\DateStrings.cpp.o
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:18: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:19: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:20: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:21: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:22: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:23: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:24: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:25: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:26: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:27: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:28: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:29: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:31: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:37: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:39: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:40: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:41: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:42: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:43: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:44: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:45: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:46: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:48: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\Time\DateStrings.cpp:49: warning: only initialized variables can be placed into program memory area
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory -ID:\Documents\Arduino\libraries\Time\utility D:\Documents\Arduino\libraries\Time\Time.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\Time\Time.cpp.o
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory -ID:\Documents\Arduino\libraries\OneWire\utility D:\Documents\Arduino\libraries\OneWire\OneWire.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\OneWire\OneWire.cpp.o
D:\Documents\Arduino\libraries\OneWire\OneWire.cpp:439: warning: only initialized variables can be placed into program memory area
D:\NotBackedUp\Reef Angel Controller\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DARDUINO=101 -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\cores\arduino -ID:\NotBackedUp\Reef Angel Controller\hardware\arduino\variants\standard -ID:\Documents\Arduino\libraries\ReefAngel_Features -ID:\Documents\Arduino\libraries\Globals -ID:\Documents\Arduino\libraries\Time -ID:\Documents\Arduino\libraries\OneWire -ID:\Documents\Arduino\libraries\RA_NokiaLCD -ID:\Documents\Arduino\libraries\InternalEEPROM -ID:\Documents\Arduino\libraries\Wire -ID:\Documents\Arduino\libraries\Memory -ID:\Documents\Arduino\libraries\RA_NokiaLCD\utility D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp -o C:\Users\JPHILL~1\AppData\Local\Temp\build4646945220764989295.tmp\RA_NokiaLCD\RA_NokiaLCD.cpp.o
In file included from D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:22:
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:115: warning: only initialized variables can be placed into program memory area
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::Clear(byte, byte, byte, byte, byte)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:681: warning: comparison between signed and unsigned integer expressions
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawSingleMonitor(int, byte, byte, byte, byte)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1249: warning: comparison between signed and unsigned integer expressions
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawMonitor(byte, byte, ParamsStruct, byte, byte)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1268: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1270: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1272: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1274: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1277: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1279: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawEEPromImage(int, int, byte, byte, int, int)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1311: error: 'class TwoWire' has no member named 'write'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1311: warning: suggest parentheses around + or - inside shift
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1312: error: 'class TwoWire' has no member named 'write'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1312: warning: suggest parentheses around + or - in operand of &
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1318: error: 'class TwoWire' has no member named 'read'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawOption(int, byte, byte, byte, char*, char*, byte)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1401: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1402: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawCancel(bool)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1430: warning: deprecated conversion from string constant to 'char*'
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawOK(bool)':
D:\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1447: warning: deprecated conversion from string constant to 'char*'
So, the softwares are located in D:/notbackedup/arduino
and the working folder is D:/documents/arduino
The libraries are located in the documents folder with all the example sketches as well.
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 0.9.6
When running the updater for the libraries, I have no clue about where they are being copied to.
So, what is wrong with my setup ???
Re: Compiling error, of course
Hummm, I think all apps are looking for standard folders within your computer.
The "Documents" folder is where everything is going when you use the libraries update utility.
I'm not so sure how your W7 is setup, but it is usually C:\Users\xxxx\Documents
What do you have on Sketchbook location on File->Preferences?
jason
Post by jason »
Ok, found out where it's coming from.....
It's exactly what you said, the arduino was pointing at the wrong folder.....shame on me :(
