iPhone app problem
Poiromaniax
iPhone app problem
Post by Poiromaniax »
Hi,
I think I've found a bug in the app.
When I try change memory values, changes don't reflect on the controller.
For instance, I was trying to change vortech mode (location 855) any change I made did not reflect
wolfador
Re: iPhone app problem
Post by wolfador »
I will look into this.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
Great!!!
I can't wait to see this fixed :) I was trying a custom memory yesterday and it didn't work :(
It would be nice to be able to read as well as write.
Also, is there a way to get vortech stuff in there too :)
wolfador
Post by wolfador »
rimai wrote: Also, is there a way to get vortech stuff in there too :)
If someone wants to send me an mp10 and the module :lol:
I will add it in as a dedicated spot instead of having to use the custom variable.
John
Cool!!
I think the labels could use the units too, so everyone knows what that number represents. Something simple like (s) to indicate seconds for example :)
mikedizon
Re: iPhone apps
Post by mikedizon »
Hi,
I was wondering if the "custom" box works in the memory?
I would like to use the mem loc and value for controlling ph with dosing.
I just downloaded the new reef angel update.
Re: iPhone apps
mikedizon wrote:Hi,
It should work. You just need to input the memory location you wish to use in there and then update the value.
mikedizon
Post by mikedizon »
Hi,
After downloading and updating the Reef Angel Libraries Version: 0.9.6 and the new update wizard 1.04.
None of the setting in the memory works. You can view the overheat temp value that but cant change any settings. I just read that when it's hard coded it won't work. Maybe this is the reason. The wizard creates hard coding. Can anyone verify if this is correct. Any work around this. Thanks ;)
SuperDodge
Post by SuperDodge »
I also can't change memory settings based on a block value.
Yeah, iphone app is broken for that part :(
John hasn't updated that yet for quite some time.
Anyone else to take over??
