I have been quite frustrated for the last several days and hope someone sees what I am doing wrong. All was seeming to be working fine until I tried to upload the code that I got from the board for random wavemaking. Now when I go to upload from Arduino I get:
Binary sketch size: 31488 bytes (of a 32256 byte maximum)
processing.app.SerialException: Serial port 'COM4' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.<init>(Serial.java:144)
at processing.app.Serial.<init>(Serial.java:76)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:75)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:93)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:56)
at processing.app.Sketch.upload(Sketch.java:1603)
at processing.app.Sketch.exportApplet(Sketch.java:1568)
at processing.app.Sketch.exportApplet(Sketch.java:1524)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2293)
at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port 'COM4' already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:99)
I noticed it first when trying to hook up my X10 interfaces but after de-installing all their software, and even re-installing the Reef Angel stuff I still get the error. I thought for a minute it had to do with the client software but I did a fresh boot asnd tried to upload prior to running the client.
Still didn't work...
In device manager there is a driver, a FT232R UART USB sitting on Com4 that I suppose belongs to RA but would like verification.
I wrote the other day about potentially changing that address thinking I could get around this problem but no other ports are offered me in either Arduino, Client SW or even installer.
Thinking the FT232R UART chip belonged to someone else, I de-installed all drivers, plugged them in one at a time and sure enough it was the RA cable that caused Windows to install this driver.
I would really appreciate the help...I am kinda stuck and not sure how to proceed. Thx in advance.
Ross
cannot upload - com4 already in use
rossbryant1956
Re: cannot upload - com4 already in use
I think it is the client.
Open the Client and go to Settings->Modify and choose General tab.
Click the button Launch Service Dash.
Make sure that you have the Listener service stopped before uploading any code.
rossbryant1956
That did it. Thx
Ross
Ross
mraaa1988
Hi guys
I am having the same problem as Ross
Binary sketch size: 1026 bytes (of a 32256 byte maximum)
processing.app.SerialException: Serial port 'COM7' already in use. Try quiting any programs that may be using it.
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:88)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:66)
at processing.app.Sketch.upload(Sketch.java:1664)
at processing.app.Sketch.exportApplet(Sketch.java:1624)
at processing.app.Sketch.exportApplet(Sketch.java:1578)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2314)
processing.app.debug.RunnerException: Serial port 'COM7' already in use. Try quiting any programs that may be using it.
What do u mean by opening the Client
Where is the Client and how I can access it
By the way I am using Windows 7 pro 64 bits
I was doing some testings with my Xbee shields and this error came so making me very frustrating
Any help would be highly appreciate
Tony
Tony
Sebyte
The reference is to the Reef Angel Client software.
Are you sure COM7 is the port that the USB cable is using?
The easiest way to find out is:
Make sure that USB-TTL cable is plugged in.
Tools->Boards
Write down all ports showing.
Remove the USB-TTL cable.
Tools->Boards
Whichever port is missing is the one you need to use to communicate with RA.
Tools->Boards
Tools->Boards
mraaa1988
Yes
That is definitely COMP7
I did try even with my friend's laptop
The error was exactly the same except I got "COMP3" instead of "COMP7"
Never experience with Reef Angel Client software before, so gonna take a while for me to understand it
Any way I ll let u guys know how I go as soon as possible
Thanks for all the help
Tony
Tony
mraaa1988
Hi guys
Somehow I can not Launch Service Dash
Keep getting this error every time I click on Launch Service Dash from Reef Angel Client v2.2/Settings/Modify/General window
ReefAngelManager has stopped working
Windows is checking for a solution to a problem...
then nothing happened
The listener status: Stopped / Retrying to connect in 00:45
The logger status: Running
I am using USB cable
still getting "Serial port 'COM7' already in use" when uploading a code to my Arduino using ReefAngel Controller
want to upload a picture but the file is too big so cant show u guys
What did I do wrong???
Please help
btw can u also show me how to upload a picture to a forum?
Tony
Please help
Tony
