Page 6 of 7
Re: Bluetooth Attachment
Posted: Fri Jan 02, 2015 5:53 pm
by snoopy60
windows 8 on my tablet
by pandimus
Mine also is immediate...
by cosmith71
Nope. During the upload, the screen should go off, and the red light should flash. When it's over it should come back up and start running.
Posted: Fri Jan 02, 2015 5:55 pm
by snoopy60
I'd like to see if anyone else has any thoughts but I can try using the cable again to see if it does the same thing. I can always switch to my desktop using win 7 now that I have blue tooth. Again, everything else seems to be perfect
Posted: Fri Jan 02, 2015 5:57 pm
by cosmith71
I use Windows 8.1 with no problems.
Posted: Fri Jan 02, 2015 5:59 pm
by snoopy60
screen on the head unit (reef angel +) goes off, red light flashes (and blue light on the BT attachment goes on). when upload finished, blue light goes off, red light stops blinking but screen doesn't come back on until I detach the BT and plug it back in.
Posted: Fri Jan 02, 2015 6:02 pm
by snoopy60
screen goes off on head unit (RA+), red light starts flashing, blue light on BT goes on. when upload finished, blue light goes off, red light stops flashing but screen doesn't come back on unit I detach and reconnect BT
Posted: Fri Jan 02, 2015 6:56 pm
by snoopy60
wonder if I ought to reinstall the software?
Any thoughts on what I should try or what might be causing this?
Posted: Fri Jan 02, 2015 6:57 pm
by Sacohen
Reinstalling can never hurt.
I'd be interested in seeing what it does on your Windows 7 system.
Posted: Fri Jan 02, 2015 6:58 pm
by cosmith71
Did you replace the rxtxSerial.dll file?
Posted: Fri Jan 02, 2015 6:59 pm
by Sacohen
I believe he said he did that earlier.
by pandimus
Does it lock up after up load? Can you do a reset command?
Posted: Fri Jan 02, 2015 7:47 pm
by snoopy60
replaced the dll.
after upload I have to disconnect the BT widget from the head unit, then it accepts the upload and works perfectly.
How do I do a "reset command." and will that help diagnose the issue?
Posted: Fri Jan 02, 2015 8:37 pm
by pandimus
I use the reset, from my reef angel app. It always gives an error but does reset it..
Posted: Fri Apr 03, 2015 7:33 am
by dedvalson
Hi,
Received my Bluetooth attachment and got it working pretty quickly.
I had a question though. Is it normal for the actual software upload to be much slower over bluetooth?
With a direct connection it takes around 6 seconds, with bluetooth it is more like 40 seconds.
Not a big deal but I just wondered.
Don
Posted: Fri Apr 03, 2015 8:11 am
Yeah, I think it is the overhead of the bluetooth connection, but I may be wrong. I never really dug deep to find out.
Posted: Fri Apr 03, 2015 6:39 pm
by 89delta
Question for ya rimai.....does the BT modual need to be an rn-41 or can any old arduino bt modual work?
Posted: Fri Apr 03, 2015 7:14 pm
I've had issues with different modules.
Posted: Mon Apr 06, 2015 5:42 pm
by AlanM
I haven't uploaded new code to my RA for a while but went to do it tonight and discovered that my bluetooth attachment wasn't talking to Win 7 anymore even though it still showed RNBT-41FC device listed. I removed the device and went to re-add it, and it fails each time. I disconnected the bluetooth from the head unit, reconnected and tried to re-add, but it failed. I rebooted the computer and it still failed.
It gives me error code 0x80004005 which probably means nothing, but are there tips folks can give to get it to connect when it insists on not connecting?
Posted: Mon Apr 06, 2015 5:45 pm
by cosmith71
Delete the driver, reboot, and then try.
Posted: Mon Apr 06, 2015 6:17 pm
by AlanM
cosmith71 wrote:Delete the driver, reboot, and then try.
Worked! Thanks for the suggestion. I pulled the dongle, rebooted, made sure no bluetooth was installed, then inserted the dongle and re-connected and it works now. I uploaded the code with DDNS enabled. I also repositioned the module a bit, but I don't know if that helped or not. It's in my basement and my computer is upstairs. Between the last time I reprogrammed and now I have drywalled the ceiling of my basement between the computer and the attachment which may drop the signal strength too.
Posted: Mon Apr 06, 2015 6:29 pm
by cosmith71
Could be. Poor signal strength does all kinds of funny things to these.
Posted: Mon Apr 06, 2015 7:14 pm
by AlanM
Hah, worked once, uploaded code. Made a small change, and after that the arduino client reports that the com port is gone. Deleting and adding this time doesn't do it an now I can't even get the com ports to come back. I bet it's a range thing. Hmm.
Posted: Tue Apr 07, 2015 4:54 am
by cosmith71
I used a USB extension cable to move my bluetooth dongle closer to the aquarium and farther away from my computer. It's much more consistent now.
http://www.amazon.com/gp/product/B00HYJ ... UTF8&psc=1
Posted: Mon Apr 13, 2015 4:41 pm
by AlanM
Colin, I have one of those that I used to run with my Apex feeder. It's even still run from the controller position upstairs to the tank right by my computer. How do you use it with your bluetooth connector?
Edit: Duh, I get it. You put the bluetooth dongle at the end of the extension with the USB end attached to your computer, not the bluetooth attachment from the RA somehow nearer the computer.
Posted: Mon Apr 13, 2015 4:43 pm
by pandimus
Plug it in, move your blue tooth adaptet closer to reef angel
Posted: Mon Apr 13, 2015 4:45 pm
by AlanM
Hah, yep, thanks. I realized that just now.
Posted: Mon Apr 13, 2015 5:14 pm
by AlanM
Suggestion works. I had a 10 foot extension cable that added just enough signal to make it pretty reliable. Thanks.
Posted: Mon Apr 13, 2015 6:28 pm
by cosmith71
Glad you figured it out.
Posted: Thu May 07, 2015 3:56 pm
by psirex
