Pm roberto.. You wont regret itpsirex wrote:How much and where can I get 1?
Bluetooth Attachment
Re: Bluetooth Attachment
- ewaldsreef
- Contact:
Just installed my Bluetooth. Its so convenient. I am glad I read the first part of this post about replacing the file.
This is perfect for someone like me who is learning the program and wants to try multiple things.
- joshlawless
What kind of range are those of you with this module getting from it? I have an iMac sitting about 9 feet from the Bluetooth module, and while it can occasionally connect, and even succeeded in uploading code once, it fails to connect or complete the upload about 90% of the time. If I sit next to the bluetooth module with my laptop, I get better results, but it sure would be nice to use the computer in my home office to update the code for the aquarium in my home office. :-/
Is there any way to implement an external antenna for the bluetooth module, like some have done for the WiFi?
Mine is probably about 10' away, through two walls and the aquarium stand. Try moving the BT module away from the other electrical equipment and away from the WiFi adapter to reduce interference.
Maybe it is the radio on your computer.
Try using an external dongle or even one of those with external antenna.
- joshlawless
Am I cursed somehow? I can sit my laptop two inches from the bluetooth module, and when I attempt to upload code from Arduino over the bluetooth connection, the light on the bluetooth module turns blue, the reef angel clicks loudly as it reboots, the blue light goes out, and the upload fails with the notice
It's only worked once, and I've had no luck since, despite removing the bluetooth device and re-pairing it, restarting Arduino, changing the serial port to something else and back, etc.
When it is connected to my Mac, I can check the RSSI. For the iMac, which is 9 feet away, it's around -60 dB. For the Macbook sitting two inches away, it's about -45 dB.
avrdude: ser_open(): can't open device "/dev/tty.RN-IAP-D497-RN-iAP": Resource busy
- joshlawless
Im using OSX platforms - I don't think the referenced .dll file is present outside of the Windows IDE.
I think it's still part of it but I could be wrong. I have the bluetooth working on my windows laptop, not my mac..
Joshlawless;
Did you ever get the Bluetooth module set up on OSX?
I just switched from PC to MAC and am getting ready to set up the RA on El Capitan.
I have this on both of my RA's now, works great!
I had no problem getting it set up on my iMac.
I actually paired it long before I reinstalled the RA software and when I finally got the RA software going the Bluetooth worked fine.
Sent from my SM-G928P using Tapatalk
Just got this and let me say this thing is awesome! I absolutely love not having to disconnect the RA to upload code. I'm always a little concerned at constant plugging/unplugging equipment (at least with small electronics). Especially after the usb-ttl gave my PC BSOD (edit: wanted to add this was specific to my PC, nothing to do with the RA), but the BT works perfect.
My PC (win 7, 64bit) did not tell me which port was incoming/outgoing, just listed com 6 and 7 being new. At first I tried 6 and it acted like it was going to load and the RA program just froze. I killed it with task manager after waiting a while and tried com 7, everything went smooth as butter. It does take a few seconds longer than if I had the usb-ttl cable but I don't have to touch anything to upload, so really time saved.
I'm about 12' away, up 1 floor.
How do I order one since I don't see it in the store
Hello, I would like to purchase such bluetooth attachement in order to upload code without cablesrimai wrote:I sent you a pm.
From what I understand with the new RA* you don’t need the Blue Tooth adapter.Armetas wrote:Hello, I would like to purchase such bluetooth attachement in order to upload code without cablesrimai wrote:I sent you a pm.
The RA* has a web or cloud interface that uploads the code.
If you are not planning on upgrading to the RA^ then you will need it.
It’s great I’ve had one since he released it.
