Page 7 of 7
Re: Bluetooth Attachment
Posted: Thu May 07, 2015 4:11 pm
by pandimus
Pm roberto.. You wont regret it
Posted: Thu May 07, 2015 5:17 pm
by Sacohen
I love it.
Posted: Thu May 28, 2015 8:05 am
by ewaldsreef
Just installed my Bluetooth. Its so convenient. I am glad I read the first part of this post about replacing the file.
This is perfect for someone like me who is learning the program and wants to try multiple things.
Posted: Mon Jun 08, 2015 11:21 pm
by joshlawless
What kind of range are those of you with this module getting from it? I have an iMac sitting about 9 feet from the Bluetooth module, and while it can occasionally connect, and even succeeded in uploading code once, it fails to connect or complete the upload about 90% of the time. If I sit next to the bluetooth module with my laptop, I get better results, but it sure would be nice to use the computer in my home office to update the code for the aquarium in my home office. :-/
Is there any way to implement an external antenna for the bluetooth module, like some have done for the WiFi?
Posted: Tue Jun 09, 2015 3:54 am
by Sacohen
Mine is about 18' away.
Never had a problem.
Posted: Tue Jun 09, 2015 7:04 am
by cosmith71
Mine is probably about 10' away, through two walls and the aquarium stand. Try moving the BT module away from the other electrical equipment and away from the WiFi adapter to reduce interference.
Posted: Tue Jun 09, 2015 7:06 am
by Sacohen
Mine goes through a wall too.
Posted: Tue Jun 09, 2015 7:56 am
Maybe it is the radio on your computer.
Try using an external dongle or even one of those with external antenna.
Posted: Tue Jun 09, 2015 5:36 pm
by joshlawless
Am I cursed somehow? I can sit my laptop two inches from the bluetooth module, and when I attempt to upload code from Arduino over the bluetooth connection, the light on the bluetooth module turns blue, the reef angel clicks loudly as it reboots, the blue light goes out, and the upload fails with the notice
avrdude: ser_open(): can't open device "/dev/tty.RN-IAP-D497-RN-iAP": Resource busy
It's only worked once, and I've had no luck since, despite removing the bluetooth device and re-pairing it, restarting Arduino, changing the serial port to something else and back, etc.
When it is connected to my Mac, I can check the RSSI. For the iMac, which is 9 feet away, it's around -60 dB. For the Macbook sitting two inches away, it's about -45 dB.
Posted: Wed Jun 10, 2015 7:48 am
Did you replace the file mentioned in the OP?
Posted: Wed Jun 10, 2015 8:47 am
by joshlawless
Im using OSX platforms - I don't think the referenced .dll file is present outside of the Windows IDE.
Posted: Wed Jun 10, 2015 7:20 pm
I think it's still part of it but I could be wrong. I have the bluetooth working on my windows laptop, not my mac..
Posted: Sat Sep 03, 2016 5:55 pm
by Sacohen
Joshlawless;
Did you ever get the Bluetooth module set up on OSX?
I just switched from PC to MAC and am getting ready to set up the RA on El Capitan.
Posted: Sun Sep 25, 2016 3:45 pm
by projectx
I have this on both of my RA's now, works great!
Posted: Sun Sep 25, 2016 3:47 pm
by Sacohen
I had no problem getting it set up on my iMac.
I actually paired it long before I reinstalled the RA software and when I finally got the RA software going the Bluetooth worked fine.
Sent from my SM-G928P using Tapatalk
Posted: Tue Dec 06, 2016 7:52 pm
by robmwpropane
Just got this and let me say this thing is awesome! I absolutely love not having to disconnect the RA to upload code. I'm always a little concerned at constant plugging/unplugging equipment (at least with small electronics). Especially after the usb-ttl gave my PC BSOD (edit: wanted to add this was specific to my PC, nothing to do with the RA), but the BT works perfect.
My PC (win 7, 64bit) did not tell me which port was incoming/outgoing, just listed com 6 and 7 being new. At first I tried 6 and it acted like it was going to load and the RA program just froze. I killed it with task manager after waiting a while and tried com 7, everything went smooth as butter. It does take a few seconds longer than if I had the usb-ttl cable but I don't have to touch anything to upload, so really time saved.
I'm about 12' away, up 1 floor.
Posted: Wed Mar 22, 2017 12:06 pm
by GugsJr
How do I order one since I don't see it in the store
Posted: Wed Mar 22, 2017 12:38 pm
I sent you a pm.
Posted: Mon Jan 29, 2018 1:58 pm
by Armetas
rimai wrote:I sent you a pm.
Hello, I would like to purchase such bluetooth attachement in order to upload code without cables
Posted: Mon Jan 29, 2018 5:17 pm
by Sacohen
Armetas wrote:rimai wrote:I sent you a pm.
From what I understand with the new RA* you don’t need the Blue Tooth adapter.
The RA* has a web or cloud interface that uploads the code.
If you are not planning on upgrading to the RA^ then you will need it.
It’s great I’ve had one since he released it.
