Re: Custom Menu Generator
Posted: Fri Jun 14, 2013 1:23 pm
Can you post the full code?
https://forum.reefangel.com/
a#include <ReefAngel_Features.h>
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "Accilmate";
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Calibrate PH";
prog_char menu6_label[] PROGMEM = "Calibrate Water Level";
prog_char menu7_label[] PROGMEM = "Clear ATO ";
prog_char menu8_label[] PROGMEM = "Clear Overheat";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.WaterChangeModeStart();
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.Relay.Override(Port6, ~bitRead(ReefAngel.Relay.RelayMaskOff, Port6Bit)*2);
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");{
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");ReefAngel.ATOClear();
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Item 9");ReefAngel.OverheatClear();
unsigned long ATOUpdate=0;
// Initialize the menu
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,30,30); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.WaterLevelATO(Port6,720,0,1);
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
}Code: Select all
void MenuEntry4()
ReefAngel.LightsOn();
void MenuEntry5()
ReefAngel.LightsOff();
