Custom Menu Generator
Since RAGen is no longer in use, there is not an easy way to create a custom menu for your controller. I took the custom menu section from RAGen and converted it into a Java application.
It will generate the code and display it in a window to be pasted into your INO file. You have the option to save the menu to an XML file for easy sharing. You can also load the menu from an XML file.
Here are a couple screenshots to show you what it looks like:
Main Screen
Main Screen
Output Screen
Output Screen
I have it released and ready for use. There is a Windows/Linux version which is just the JAR file that you can download and run. The Mac version is a DMG file. The DMG file just opens up and allows you to run the application or you can install it in your Applications by dragging it into your app folder.
Grab a copy and see what you think. Feedback is always welcome.
Java Version: http://curtbinder.info/apps/MenuGenerator-1.0.0.jar
Mac Version: http://curtbinder.info/apps/MenuGenerator-1.0.0.dmg
All apps: http://curtbinder.info/apps/
Reason: Updated download links
Awesome!!!
Re: Custom Menu Generator
:ugeek: Cool!!
agentgreen
Post by agentgreen »
Yet another reason this controller is #1.
just a quick update...
i have the loading from xml file working. i have only tested it out on a windows 7 machine. i am going to test it on linux and mac later today (hopefully). if all goes well with it, i will be releasing version 1 in the next couple days.
I edited the original post but forgot to comment to tell everybody that I released the Menu Generator.
In the original post, there are links to download it. One download for Linux & Windows and another for Mac. The Mac version is just a DMG with the application inside of it. There's not a fancy installer for it. The Linux & Windows version just needs to download the JAR file and run it.
Feedback is always welcome. Enjoy. :ugeek:
alexwbush
Post by alexwbush »
Are menus inside menus possible (i.e. a calibration menu for pH, salinity, and water level)?
Also, water level calibration is missing :-P
alexwbush wrote:Are menus inside menus possible (i.e. a calibration menu for pH, salinity, and water level)?
no, you cannot have nested menus.
i haven't updated it and didn't realize that water level calibration was in the libraries. guess i had better update it.
alexwbush
Post by alexwbush »
Is there any push for it in the future? :D
binder wrote:[
Are nested menus doable at all? I'd love to be able to setup a Calibration menu for instance with pH, and Water Level and whatever else may go in there... or a "Lights" menu, so forth and so forth..
What's the current limit on number of menu items?
Lee
Currently, there is a limit of 9 menu items (that fills up the screen). It can only be a flat menu (single list). This is the limitations with using a Custom Menu.
As you know, the default menu has nested menus. This works because the menus do not change and are embedded within the libraries itself. It is much easier this way to handle one level deep with the menu system embedded.
When I was initially creating the menu system, I wanted to do nested menus but as I tried various things to get it to work, the code base increased (bad when working with limited memory) and other errors were occurring that were big errors (system locking up, screen freezing, etc). I was trying to use pointers and dynamically create the menu on the fly. Since the controller has limited RAM, I was running out of RAM and pointers were getting overwritten and it was a disaster. There hasn't been a lot of requests to have a custom nested menu. Ideally, I would like to separate out the UI from the core libraries so you can have the basics in the libraries and then a separate UI to handle the displaying. This would have been important had some of the other custom displays been developed.
It sounds like I may need to revisit this topic and see if I can come up with another way to handle it.
Toolboy
Post by Toolboy »
The limit of 9 menu items. Does that include the ones already preloaded on my reef angel?
Reason Im asking is cause my LED unit is going to be 6 colours and need to be able to set each one at the max % that I want to get to achieve the colour Im looking for. eg White 100% Blue 100% UV 40% red 30% ect and then let the pwm slope do ramping up and down
Toolboy wrote:The limit of 9 menu items. Does that include the ones already preloaded on my reef angel?
Can you create a new post for this?
There may be easier solutions other than menu entries
Toolboy
Post by Toolboy »
Hi Roberto
Ive done as you requested
http://forum.reefangel.com/viewtopic.php?f=8&t=2291
Please could you move binder answer to the new thread
Redadeath
Post by Redadeath »
How can I run jar file on vista thank you
when it comes to programming i "always need help "
You need java
I created a custom menu last night and everything seems to be working, but the lights on/off aren't working.
I entered this in the setup function after ReefAngel.init():
// Initialize the menu
And this is entered in the Global section.
#include <avr/pgmspace.h>
prog_char menu2_label[] PROGMEM = "Accilmate";
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Calibrate PH";
prog_char menu6_label[] PROGMEM = "Calibrate Water Level";
prog_char menu7_label[] PROGMEM = "Clear ATO ";
prog_char menu8_label[] PROGMEM = "Clear Overheat";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label  };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.WaterChangeModeStart();
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.Relay.Override(Port6, ~bitRead(ReefAngel.Relay.RelayMaskOff, Port6Bit)*2);
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif  // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif  // RelayExp
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");{
  ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");ReefAngel.ATOClear();
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Item 9");ReefAngel.OverheatClear();
you have to make sure you have the lights on ports set in your ino file in order for it to work properly.
Yeah I do.
The are on Ports1 and Ports2 and work properly under the original menu and the Andriod App.
Can you post the full code?
Here you go.
a#include <ReefAngel_Features.h>
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
void MenuEntry9()
unsigned long ATOUpdate=0;
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,30,30); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.WaterLevelATO(Port6,720,0,1);
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
Try this:
void MenuEntry4()
  ReefAngel.LightsOn();
void MenuEntry5()
  ReefAngel.LightsOff();
Tried that Roberto and same thing. Nothing happened. :(
It's showing your ports are on. Nothing is going to happen when ports are on. LightsOn() would override on and LightsOff() just cancels the override. It doesn't actually override it off.
So, if your lights are already on, overriding it on would do nothing.
Ok. Sorry. I thought it would over ride then to turn off if they were on too.
They are working properly.
The other code I had probably worked too.
