Re: water change build
Posted: Fri Jan 22, 2016 10:38 pm
ok. I think I know the answer to that one..
a little back to the drawing board. One moment.
https://forum.reefangel.com/
//Waterchange Mode
static time_t wc_drain=0;
static time_t wc_tankoff=0;
static time_t wc_tankup=0;
static time_t wc_refill=0;
static int stage=0;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0))
{ // At 6pm every day the following to occur or when WC mode is activated
wc_tankoff=now();
stage=1;
if (now()-wc_tankoff < 300 && stage==1)
} else {
wc_drain=now();
wc_tankoff=0;
stage=2;
if (now()-wc_drain < 300 && stage==2)
ReefAngel.Relay.On(Box1_Port4);
ReefAngel.Relay.Off(Box1_Port4);
} else {
wc_tankup=now();
wc_drain=0;
stage=3;
if(now()-wc_tankup < 300 && stage==3)
ReefAngel.Relay.On(Box1_Port8);
} else {
wc_refill=now();
wc_tankup=0;
stage=4;
if (now()-wc_refill < 300 && stage==4)
if (ReefAngel.HighATO.IsActive()) wc_refill=0;
} else {
//ButtonPress++;
wc_refill=0;
stage=0;
if (ReefAngel.HighATO.IsActive()) { wc_refill=0; stage=0 };
#include <Moon.h>
//Standard Dimming//
byte ActinicPWMValue=0; // For cloud code
byte DaylightPWMValue=0; // For cloud code
//Dimmer Expansion//
byte WhitePWMValue=0;
byte Actinic1PWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
InternalMemory.LCDID_write(0);
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
ReefAngel.StandardHeater( Port2,220,225 );
ReefAngel.StandardLights( Port3,8,00,16,00);
ReefAngel.StandardFan ( Port4,230,238 );
ReefAngel.StandardLights( Port7,21,00,5,00 );
ReefAngel.StandardLights( Port8,5,00,21,00 );
ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//White off
if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
ReefAngel.Relay.Off(Port8);
} else {
//Display in Failsafe//
//boosterpump//
ReefAngel.Relay.Off(Box1_Port2);
//Lighting Control//
ActinicPWMValue=PWMSlope(5,00,21,00,0,100,180,ActinicPWMValue);
DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
Actinic1PWMValue=PWMSlope(5,00,21,00,0,80,180,Actinic1PWMValue);
SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
MoonPWMValue=PWMSlope(21,00,5,00,0,MoonPWMValue,235,0);
CheckCloud();
//Lighting expansion control//
ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
ReefAngel.PWM.SetChannel( 1, Actinic1PWMValue);
ReefAngel.PWM.SetChannel( 2, SupPWMValue);
ReefAngel.PWM.SetChannel( 3, SupPWMValue);
ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
//Waterchange Mode
static int stage=0;
wc_tankoff=now();
stage=1;
} else {
wc_drain=now();
wc_tankoff=0;
stage=2;
} else {
wc_tankup=now();
wc_drain=0;
stage=3;
} else {
wc_refill=now();
wc_tankup=0;
stage=4;
} else {
//ButtonPress++;
wc_refill=0;
stage=0;
ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(6,30)
#define Lightning_Change_per_Cloud 60
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhitePWMValue=DaylightPWMValue;
MoonPWMValue=DaylightPWMValue;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
else x=57;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
void Strike()
byte n;
int newdata;
byte a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (byte i=0; i<a; i++)
// Flash on
analogWrite(daylightPWMPin,255); // Flash on daylight port
newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 0.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
newdata=ReefAngel.PWM.GetChannelValue(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
Wire.write(0x8+(4*1));
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
//Waterchange Mode
static time_t wcTimer=0;
static int stage=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE);
wcTimer=now();
if (now()-wcTimer >= 1 && now()-wcTimer < 600)
if (now()-wcTimer >= 60 && now()-wcTimer < 120)
if (now()-wcTimer >= 120 && now()-wcTimer < 180)
if (!ReefAngel.HighATO.IsActive())
// } else {
// ButtonPress++;
}Code: Select all
//Waterchange Mode
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE && wcTimer==0);
wcTimer=now();
if (now()-wcTimer >= 1 && now()-wcTimer < 120)
} else {
wcTimer=0;
// ButtonPress++;
#include <Moon.h>
byte SupPWMValue=0;
// ReefAngel.AddSalinityExpansion(); // Salinity Expansion Module
// ReefAngel.AddORPExpansion(); // ORP Expansion Module
// Default Ports
ReefAngel.Relay.On(Port1); //Sump Skimmer
ReefAngel.Relay.Off(Box1_Port1); //Sump Out
ReefAngel.Relay.On(Box1_Port6); //Sump Light
ReefAngel.Relay.Off(Box1_Port4); //Sump Out
// Place additional initialization code below here
// Place additional initialization code above here
ReefAngel.StandardHeater(Port2,220,225); //Sump Heater
ReefAngel.Relay.Set(Port3,ReefAngel.PWM.GetChannelValue(2)>0); //Sup Power
ReefAngel.StandardFan(Port4,230,238); //Chiller
ReefAngel.Relay.Set(Port7,ReefAngel.PWM.GetChannelValue(4)>0); //Moon Power
ReefAngel.Relay.Set(Port8,ReefAngel.PWM.GetChannelValue(1)>0); //White / Blue Power
ReefAngel.StandardLights( Box1_Port5,8,00,16,00 ); //Display Color
ReefAngel.Relay.On(Box1_Port7); //4FT In
//Sump out
if (ReefAngel.Relay.isMaskOn(Box1_Port4) && !ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Box1_Port4,0);
//Salt In
if (ReefAngel.Relay.isMaskOn(Box1_Port1) && ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Box1_Port1,0);
//White off
} else {
//Boosterpump//
// Turn off Air Pump if Skimmer has been shutoff
if (ReefAngel.Relay.Status(Port1)>0)
ReefAngel.Relay.Off(Port6);
ActinicPWMValue=PWMSlope(5,00,21,00,10,100,180,ActinicPWMValue);
DaylightPWMValue=PWMSlope(6,30,18,30,10,70,180,DaylightPWMValue);
Actinic1PWMValue=PWMSlope(5,00,21,00,2,80,180,Actinic1PWMValue);
MoonPWMValue=PWMSlope(21,00,5,00,1,MoonPhase(),235,0);
CheckCloud();
//Waterchange Mode
wcTimer=now();
} else {
wcTimer=0;
// ButtonPress++;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
//MoonPWMValue=DaylightPWMValue;
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
// Flash on
newdata=4095;
cstart*=60;
cend*=60;
static byte status=255;
static int LastDisplayedMenu=-1;
if (LastDisplayedMenu!=WATERCHANGE_MODE && ReefAngel.DisplayedMenu==WATERCHANGE_MODE) status=0;
LastDisplayedMenu=ReefAngel.DisplayedMenu;
if (status==0)
status=1;
if (status==1)
ButtonPress++;
status=255;
ReefAngel.LCD.DrawText(0,255,10,70,status);
static byte OldTempRelay=0;
if (TempRelay!=OldTempRelay)
OldTempRelay=TempRelay;
ReefAngel.LCD.DrawOutletBox(12, 80, TempRelay);
status=1;I'm not following what you are saying.I need the switch to function, switching on and off, over a time period so it can drain all of the water from the sump. It can take a while for the tanks to finish draining.
