water change build
tyson_mitchell_88
water change build
Post by tyson_mitchell_88 »
Hi all, I would like some help to write some Script for a water change setup. If this sounds out of wack let me know. Just trying to use what I have available.
At 6pm every day the following to occur
>box1 port 7 & 8 to turn off
>Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
>turn on box 1 port 7 & 8
>run box 1 port 1 until ato high is on for 10 mins (Salt In)
>return to usual
#include <Moon.h>
//Standard Dimming//
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
//Dimmer Expansion//
byte WhitePWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    ReefAngel.StandardHeater( Port2,220,225 );
    ReefAngel.StandardLights( Port3,8,00,16,00);
    ReefAngel.StandardFan   ( Port4,230,238 );
    ReefAngel.StandardLights( Port7,21,00,5,00 );
    ReefAngel.StandardLights( Port8,5,00,21,00 );
    ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//Display in Failsafe//
      ReefAngel.Relay.Off(Box1_Port8);
//boosterpump//
      ReefAngel.Relay.Off(Box1_Port2);
//Lighting Control//
    ActinicPWMValue=PWMSlope(5,00,21,00,0,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
    WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
    SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
    MoonPWMValue=PWMSlope(21,00,5,00,0,30,235,0);
    CheckCloud();
//Lighting expansion control//
    ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
    ReefAngel.PWM.SetChannel( 1, ActinicPWMValue);
    ReefAngel.PWM.SetChannel( 2, SupPWMValue);
    ReefAngel.PWM.SetChannel( 3, SupPWMValue);
    ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
    ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
    ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(6,30)
#define Lightning_Change_per_Cloud 60
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
   static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      WhitePWMValue=DaylightPWMValue;
      MoonPWMValue=DaylightPWMValue;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
void Strike()
  byte n;
  int newdata;
  byte a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (byte i=0; i<a; i++)
    // Flash on
    analogWrite(daylightPWMPin,255);    // Flash on daylight port
    newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    // Flash off.  Return to baseline.
    analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
    newdata=ReefAngel.PWM.GetChannelValue(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    Wire.write(0x8+(4*1));
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
Last edited by tyson_mitchell_88 on Sat Jan 16, 2016 6:27 am, edited 2 times in total.
Re: water change build
Sorry haven't had a chance to get to this one yet. Hang in, will try later this week/weekend
tyson_mitchell_88
All good mate. Thank you :)
tyson_mitchell_88
Any luck having a look at this one Lee?
No but its a 3 day weekend and I'll be doing some of my own coding so I should have a chance. Sorry man.
What is Box1_Port7 and Box1_Port8? Are you sure you want them to turn back on before the return to usual?
>return to usual
Try this. I wasn't sure how you wanted the 10 minutes handled. It's setup as a timeout here. Also I assumed those two ports to wait until the "return to usual".
  static byte wc_start=false;
  static time_t wc_drain=0;
  static time_t wc_refill=0;
  if (hour()==18 && minute()==0 && !wc_start) {   // At 6pm every day the following to occur
    wc_start==true;
    wc_drain=now()+600;
  if (wc_start) {
    // box1 port 7 & 8 to turn off
    ReefAngel.Relay.Off(Box1_Port7);
    if (now() < wc_drain || !ReefAngel.HighATO.IsActive()) {  // Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
    } else if (now() < wc_refill || ReefAngel.HighATO.IsActive()) { // run box 1 port 1 until ato high is on for 10 mins (Salt In)
      ReefAngel.Relay.Off(Box1_Port4);
    } else { // return to usual
      wc_start=false;
      ReefAngel.Relay.Off(Box1_Port1);
      // turn on box 1 port 7 & 8
tyson_mitchell_88
This is awesome thanks Lee. Port 7 & 8 are my tank returns so I will need them to go on before Salt In. Have amended as below. Compiles fine, now to see it in action tonight :D
Would it take much to add a trigger to active when water change mode is activated?
    wc_start==true;
    wc_drain=now()+600;
  if (wc_start) {
      wc_start=false;
tyson_mitchell_88
I have changed the time on this to test and haven't had a result. Just wanted to check that this all goes into void loop?
#include <Moon.h>
byte SupPWMValue=0;
//boosterpump//
    ActinicPWMValue=PWMSlope(5,00,21,00,11,100,180,ActinicPWMValue);
    CheckCloud();
//Waterchange Mode
  if (hour()==05 && minute()==30 && !wc_start) {   // At 6pm every day the following to occur
    wc_start==true;
    wc_drain=now()+600;
  if (wc_start) {
      wc_start=false;
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
    // Flash on
    newdata=4095;
  cstart*=60;
  cend*=60;
Ok, try this to trigger with WC and to have return pumps go on before salt in.
  if ((ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0)) && !wc_start) {   // At 6pm every day the following to occur or when WC mode is activated
    wc_start==true;
    wc_drain=now()+600;
  if (wc_start) {
      wc_start=false;
tyson_mitchell_88
im not having a response from waterchange mode either.
Try this:
    wc_start=true;
    wc_drain=now()+600;
  if (wc_start) {
    if (now() < wc_drain && ReefAngel.HighATO.IsActive()) {  // Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
    } else if (now() < wc_refill && !ReefAngel.HighATO.IsActive()) { // run box 1 port 1 until ato high is on for 10 mins (Salt In)
      wc_start=false;
tyson_mitchell_88
Now it works through the drain stage properly. Timer isn't working and not changing to the fill stage, or then back to normal.
Last edited by tyson_mitchell_88 on Mon Jan 18, 2016 12:23 pm, edited 1 time in total.
I thought the drain stage is working properly? Can you please accurately describe what is happening?
tyson_mitchell_88
I have just done a re-test.
when I activate waterchange mode
>Box 1 port 7 & 8 stop
>box1 port 4 runs until ATOhigh is off
>stalls
It seems after the timed amount my DayLight leds flash. Ra stays like this, flashing the leds after the timed amount, until I reset it.
Sorry mate i'm getting up through the night to try get this nutted with the time difference. Thanks again for the help.
Last edited by tyson_mitchell_88 on Mon Jan 18, 2016 10:40 pm, edited 1 time in total.
Ok got it. I'll take a look in a bit. Thanks for bearing with me. Not sure why the leds are flashing, sounds like your hitting a bus lock.
tyson_mitchell_88
I had removed my expansiin hub because it was causing some problems. My lcd is shot so maybe it throwing something :(
Ok, try this. I think this should be a bit simpler and do what you need. I also had it exit WaterChange Mode. You can remove the ButtonPress++; if you want to exit manually.
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0)) {   // At 6pm every day the following to occur or when WC mode is activated
    wc_drain=now()+600;
    wc_drain=0;
    wc_refill=now()+600;
    wc_refill=0;
    ButtonPress++;
tyson_mitchell_88
Just uploaded, as soon as it was done port 7 & 8 kept switching on and off.
When I manually pushed the float switch to the off position Port 1 was activated and port 7 & 8 stayed off.
tyson_mitchell_88
I changed if (ReefAngel.DisplayedMenu=WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0)) to only have = instead of ==.
Now once I upload (ATOHigh is on), ports 7 & 8 turn off and port 4 turns on.
When I manually change ATOHigh to off, ports 1, 7 & 8 turn on and port 4 turns off.
I need ports 7 & 8 to not toggle from the float switch. They are my tank returns, just need to turn off before wc drain and turn on before wc refill.
Those should be == not =
I'll have to look more closely at what I'm doing. The switches could also be flipping if that's where they are set to. It's nice to deal with two switches instead of one. Have to figure out how to deal with that. Sorry this has been a pain.
Ok try this one. Last attempt tonight.
    wc_drain=now()+600;
  if (now() < wc_drain) {  // Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
    if (!ReefAngel.HighATO.IsActive()) wc_drain=0;
    wc_drain=0;
  if (now() < wc_refill) { // run box 1 port 1 until ato high is on for 10 mins (Salt In)
    if (ReefAngel.HighATO.IsActive()) wc_refill=0;
    ButtonPress++;
    wc_refill=0;
tyson_mitchell_88
As soon as it uploaded port 1 turned on. 7 & 8 are on. Float switch changes nothing.
I appreciate this a lot mate. Sorry I'm not more of a help. Need to learn more.
Roberto, or someone else, can you look at the code I've written. I'm not sure what I've done wrong :(
tyson_mitchell_88
I have spread it out a bit to get my head around everything.
Now I am going through each bit at a time and testing. I have gotten this far.
Seems there is no actual 300 second delay between the modes.
//Waterchange Mode
  static time_t wc_tankoff=0;
  static time_t wc_tankup=0;
    wc_tankoff=now()+300;
  if (now() < wc_tankoff)
    wc_drain=now()+300;
    wc_tankoff=0;
  if (now() <wc_drain)
    wc_tankup=now()+300;
    wc_drain=0;
//  if(now() <wc_tankup)
//    ReefAngel.Relay.On(Box1_Port7);
//    ReefAngel.Relay.On(Box1_Port8);
//  } else {
//    wc_refill=now()+300;
//    wc_tankup=0;
//  if (now() < wc_refill)
//    ReefAngel.Relay.On(Box1_Port1);
//    if (ReefAngel.HighATO.IsActive()) wc_refill=0;
//  } else {
//    ReefAngel.Relay.Off(Box1_Port1);
    //ButtonPress++;
//    wc_refill=0;
Yeah to me you're check is instantly going to go to the next step because from the beginning wc_tankoff is 300 seconds into the future. You're check says if now() is less than the wc_tankoff value then wc_drain is now()+300 and wc_tankoff is 0 hmmm so wc_tankoff will always be > than now() so I don't see it going to the next step. Let me review what I posted....
Yes.. that looks like the issue. :) Let me try switching some logic around I think that may help. I'll use your variables
Try this:
//Waterchange Mode
    wc_tankoff=now();
  if (now()-wc_tankoff < 300)
    wc_drain=now();
    wc_tankoff=0;
  if (now()-wc_drain < 300)
    wc_tankup=now();
    wc_drain=0;
  if(now()-wc_tankup < 300)
    wc_refill=now();
    wc_tankup=0;
 if (now()-wc_refill < 300)
    //ButtonPress++;
    wc_refill=0;
So the correct logic is to subtract the time the trigger was made from the current time. If the diff is less than the time we want to run then we're good. Once the clock goes past 300 seconds into the future, the time recorded for the trigger will always be better than the runtime. Reverting it to 0 is redundant but good to make it clear. I think this will work now :) Good Luck
Here's an example from my INO with working code. When we trigger the Swabbie to run, it runs for two minutes, otherwise we treat it like a dosing pump and run it 4 times a day for 2 minutes
  static time_t t;
  // Manual mode
  if (ReefAngel.Relay.isMaskOn(Swabbie)) {
    ReefAngel.Relay.Auto(Swabbie);
    t=now();
  if (now()-t < runtime) {
    ReefAngel.Relay.On(Swabbie);
    ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
Now that you helped me see what I was doing wrong, it all makes sense now :)
tyson_mitchell_88
lnevo wrote:Here's an example from my INO with working code. When we trigger the Swabbie to run, it runs for two minutes, otherwise we treat it like a dosing pump and run it 4 times a day for 2 minutes
  static time_t t;
  // Manual mode
    t=now();
So MaskOn is seeing when you manually change the port?
tyson_mitchell_88
When I upload it is triggering everything. Will go through some troubleshooting again.
lnevo wrote:Yeah to me you're check is instantly going to go to the next step because from the beginning wc_tankoff is 300 seconds into the future. You're check says if now() is less than the wc_tankoff value then wc_drain is now()+300 and wc_tankoff is 0 hmmm so wc_tankoff will always be > than now() so I don't see it going to the next step. Let me review what I posted....
Try this:
//Waterchange Mode
    wc_tankoff=now();
    wc_drain=now();
    wc_tankoff=0;
    wc_tankup=now();
    wc_drain=0;
    wc_refill=now();
    wc_tankup=0;
    //ButtonPress++;
    wc_refill=0;
