how many led drivers can i connect?
ahmedess
Post by ahmedess »
How many Mean Well ELN-60-48P drivers can I connect to the controller?
NanoTrevor
Re: how many led drivers can i connect?
Post by NanoTrevor »
well for independent control, 2. you will also need the pwm booster as the meanwells need a 0-10 volt for dimming. you could connect at least a couple to each channel and they would run together. or if theyre not dimming as many as you can wire to your power supply then plug it into the port of choice.
With the PWM booster, you can connect virtually unlimited in the same channel.
The drivers don't pull current that would affect the booster.
The controller has 2 channels standard and 6 extra channels that you can get from an expansion module.
ahmedess
Post by ahmedess »
Thats great I just wanned to make sure so that i dont damage the booster
