how many led drivers can i connect?
Posted: Sat Jun 11, 2011 12:26 pm
by ahmedess
How many Mean Well ELN-60-48P drivers can I connect to the controller?
Re: how many led drivers can i connect?
Posted: Sat Jun 11, 2011 6:35 pm
by NanoTrevor
well for independent control, 2. you will also need the pwm booster as the meanwells need a 0-10 volt for dimming. you could connect at least a couple to each channel and they would run together. or if theyre not dimming as many as you can wire to your power supply then plug it into the port of choice.
Posted: Sun Jun 12, 2011 8:41 am
With the PWM booster, you can connect virtually unlimited in the same channel.
The drivers don't pull current that would affect the booster.
The controller has 2 channels standard and 6 extra channels that you can get from an expansion module.
Posted: Sun Jun 12, 2011 11:16 am
by ahmedess
Thats great I just wanned to make sure so that i dont damage the booster
