paradise trouble
reefcycle
paradise trouble
Post by reefcycle »
ok, so I finally figured out basics after rereading manuals 30 times! :) I finally made my code and it says sketch to big. so I am curious if it is because I uploaded to many codes? When you generate compile and send code does the code just keep on adding and adding? if so how do I reset device and try again?
reefcycle
Re: paradise trouble
Post by reefcycle »
// Autogenerated file by RAGen (v1.2.2.171), (04/10/2012 21:00)
// RA_041012_2100.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define RFEXPANSION
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.StandardLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.Portal("reefcycle", "zzxx4118");
rossbryant1956
Post by rossbryant1956 »
yes, it is something like that. I read somewhere on here that Arduino caches code to "help" you do things faster. Make sure your production copy of your code is saved, exit everything and restart and try to reload. This should do it
reefcycle
Post by reefcycle »
ok so I restarted and power cycled and uploaded new code successfully, now I unplug and still have the Memory Updated upload your INO code. I read that could be custom menu/simple menu and I corrected it to simple menu but no fix. what to do?
// Autogenerated file by RAGen (v1.2.2.171), (04/10/2012 21:51)
// RA_041012_2151.ino
#define wifi
#define SIMPLE_MENU
#define RFEXPANSION
reefcycle
Post by reefcycle »
Sent from my MB865 using Tapatalk 2
To reduce the size, open RAGen, move to features tab and make sure you have simple menu checked.
The screen shot says that you have uploaded the initial internal memory code.
Now, you need to go to RAGen, generate a code and upload it. You could also use one of the example codes to check them out.
reefcycle
Post by reefcycle »
Ok so I am so a newb. I could be completely off . I read the pdf's and opened ragen and followed the instructions. Uploaded code and still got the memory updated error again. I am trying ultimately to write a code for simple basic timer for actinic and mh. I was going to add options as I got more comfortable.
I don't think the code is being uploaded right if the screen doesn't change.
Do you have any error code at the bottom with red letters?
reefcycle
Post by reefcycle »
Ok so I uploaded internal memory code as the where to start guide informs. And then I went to features clicked options I thought I needed and originally had custom menu selected. Then switched to simple menu. And then modified relay ports to adhere to my lights (actinic and metal halides) generated the code and then verified and then uploaded code. I got the upload complete no errors and same screen. After uploading code is there a proper reset or reboot that I am missing maybe?
No, it should not need it. It will always use whatever code is being uploaded last.
Can I see the code you are trying to upload?
reefcycle
Post by reefcycle »
the code I posted this is the last thing I tried to enter
#define wifi
#define SIMPLE_MENU
#define RFEXPANSION
Ok, can you copy and paste what Arduino showing you at the bottom on red letter?
reefcycle
Post by reefcycle »
I will when I go home. Here's a question after opening arduino and plugging in reef angel how do I access code that is current on controller
You can't.
But you should have the source code saved on your computer though.
reefcycle
Post by reefcycle »
in ragen internal memory code created and loaded sucess
// Autogenerated file by RAGen (v1.2.2.171), (04/11/2012 18:39)
// Memory_041112_1839.ino
// This file sets the default values to the Internal Memory
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(13);
    InternalMemory.MHOnMinute_write(0);
    InternalMemory.MHOffHour_write(19);
    InternalMemory.MHOffMinute_write(0);
    InternalMemory.StdLightsOnHour_write(9);
    InternalMemory.StdLightsOffHour_write(20);
    InternalMemory.StdLightsOffMinute_write(0);
    InternalMemory.WM1Timer_write(200);
    InternalMemory.WM2Timer_write(354);
    InternalMemory.DP1Timer_write(10);
    InternalMemory.LEDPWMDaylight_write(50);
    InternalMemory.LEDPWMActinic_write(50);
    InternalMemory.HeaterTempOn_write(780);
    InternalMemory.HeaterTempOff_write(791);
    InternalMemory.ChillerTempOn_write(810);
    InternalMemory.ChillerTempOff_write(785);
    InternalMemory.ATOTimeout_write(60);
    InternalMemory.PHMax_write(840);
    InternalMemory.PHMin_write(550);
    InternalMemory.MHDelay_write(5);
    InternalMemory.ATOHighTimeout_write(60);
    InternalMemory.DP1RepeatInterval_write(0);
    InternalMemory.DP2RepeatInterval_write(0);
    InternalMemory.SalMax_write(2550);
    InternalMemory.PWMSlopeStartD_write(15);
    InternalMemory.PWMSlopeEndD_write(100);
    InternalMemory.PWMSlopeDurationD_write(60);
    InternalMemory.PWMSlopeStartA_write(15);
    InternalMemory.PWMSlopeEndA_write(100);
    InternalMemory.PWMSlopeDurationA_write(60);
    InternalMemory.RFMode_write(0);
    InternalMemory.RFSpeed_write(100);
    InternalMemory.RFDuration_write(10);
    InternalMemory.PWMSlopeStart0_write(15);
    InternalMemory.PWMSlopeEnd0_write(100);
    InternalMemory.PWMSlopeDuration0_write(60);
    InternalMemory.PWMSlopeStart1_write(15);
    InternalMemory.PWMSlopeEnd1_write(100);
    InternalMemory.PWMSlopeDuration1_write(60);
    InternalMemory.PWMSlopeStart2_write(15);
    InternalMemory.PWMSlopeEnd2_write(100);
    InternalMemory.PWMSlopeDuration2_write(60);
    InternalMemory.PWMSlopeStart3_write(15);
    InternalMemory.PWMSlopeEnd3_write(100);
    InternalMemory.PWMSlopeDuration3_write(60);
    InternalMemory.PWMSlopeStart4_write(15);
    InternalMemory.PWMSlopeEnd4_write(100);
    InternalMemory.PWMSlopeDuration4_write(60);
    InternalMemory.PWMSlopeStart5_write(15);
    InternalMemory.PWMSlopeEnd5_write(100);
    InternalMemory.PWMSlopeDuration5_write(60);
    // display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, "   RA code file");
    delay(5000);
red part
Binary sketch size: 5584 bytes (of a 32256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\ADMINI~1\AppData\Local\Temp\build8844919463936784050.tmp\Memory_041112_1839.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
reefcycle
Post by reefcycle »
then the controller tab generate
// Autogenerated file by RAGen (v1.2.2.171), (04/11/2012 18:43)
// RA_041112_1843.ino
#define wifi
#define SIMPLE_MENU
#define RFEXPANSION
red part
Binary sketch size: 29406 bytes (of a 32256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\ADMINI~1\AppData\Local\Temp\build8321643892134354867.tmp\RA_041112_1843.cpp.hex:i
avrdude: Recv:
reefcycle
Post by reefcycle »
ok I loaded initial internal memory
and then loaded template
same picture
WTF
reefcycle
Post by reefcycle »
ok tried another laptop and tried setups I am going to flip...
The red log tells me that it is not uploading the code.
reefcycle
Post by reefcycle »
What do u recommend then?
reefcycle
Post by reefcycle »
Ty rimai for helping me last night! One last q. My time is off. Is there a simple way to correct date n time without messing with it and rewriting scripts or is that required?
You can do with the android phone or portal.
I think wolfador is trying to get that feature available in the iPhone too.
reefcycle
Post by reefcycle »
I believe my wifi timed out. Getting bad URL. Ill check it later. But I use Android so when I get it all live again I try
reefcycle
Post by reefcycle »
ok everything works, but heres the question I have, when my cell is on the same wifi as my reef angel, I get live views every time I refresh on the app. as soon as I attempt to connect after removing my cell from wifi it doesnt connect. what should I do or what am I missing?
wolfador
Post by wolfador »
reefcycle wrote:ok everything works, but heres the question I have, when my cell is on the same wifi as my reef angel, I get live views every time I refresh on the app. as soon as I attempt to connect after removing my cell from wifi it doesnt connect. what should I do or what am I missing?
you may be using your internal address on your phone, you should use your external IP. It is easiest to configure a url at dyndns.com
John
reefcycle
Post by reefcycle »
Hey wolfador, I believe you are correct, but before I pay 20 for a dyndns, what do I need to do to make it work? do I need to keep a computer linked to the RA? Lol I am such a newb, p.s. I am an auto mechanic, if anyone needs advice I will happily help as a return favor! :)
Mike
wolfador
Post by wolfador »
reefcycle wrote:Hey wolfador, I believe you are correct, but before I pay 20 for a dyndns, what do I need to do to make it work? do I need to keep a computer linked to the RA? Lol I am such a newb, p.s. I am an auto mechanic, if anyone needs advice I will happily help as a return favor! :)
Mike
It looks like dyndns may have gotten rid of the free accounts. You can use http://www.no-ip.com/services/managed_d ... c_dns.html just open a free account and point it to your "external ip address". You can find that by going to http://www.whatismyip.com/ from your home computer.
After that you will need to open the firewall port (2000) on your router/modem and point it to the "internal" address that you have been currently using. You can find the guide for your router at:
http://portforward.com/english/routers/ ... rindex.htm
John
No need for DDNS anymore :)
http://forum.reefangel.com/viewtopic.php?p=8307#p8307
I've made a change on the server.
It only working for users that have populated the field in the past and then blanked it out.
I still gotta find some time to troubleshoot the bug that is causing it to not populate the field if it does not exist in the database.
Mike
You won't need to pay 20 for a dyndns account. I would use the free no-ip.com account instead. I've got both a no-ip and a dyndns account (had the dyndns account for many years). That's only necessary if you are wanting to use the android app. Like Roberto said, the portal uses the IP address automatically.
reefcycle
Post by reefcycle »
Ty guys. I worked it out. Just had a weird firmware on my router. But full on working.
