Wifi setup not working
Saltydogg
Post by Saltydogg »
Ok got the wifi module connected to network but when I uploaded the wifi test code to the controller then connected to wifi module and entered the ip address given during the setup on the wifi utility nothing comes up with that ip address? Am I completely missing something? Another question is the port given to me in ip address is 8080 is that right?? Any help appreciated :)
Re: Wifi setup not working
That does not look correct.
Can you take a screen shot of the wifi utility and post here?
Saltydogg
Post by Saltydogg »
How can I screen shot it into this forum?
It does say
Associated: true
Authenticated: true
DHCP: true
Mode: WPA2
IP address and port: 192.168.1.67:8080
Then the verbiage about if blue light is still blinking ...wifi could not connect to network
FYI I have a steady blinking green light no blue so I am assuming I am connected to wifi.
At the bottom it does say
Trying to connect to your router...
Does that mean anything??
You can use it that way with port 8080 or you can restore factory settings and do over again.
If you use that way, browse http://192.168.1.67:8080 with the wifi attachment connected to your RA.
Do you get anything now?
Saltydogg
Post by Saltydogg »
Nothing. To ensure I have test code procedure right.... I selected wifi test from examples menu, uploaded to controller and as soon as that was done I connected the wifi module. The module had a blnking green light but on the actual controller screen it showed wifi setup already done and then at bottom said up?
You have the wrong code then.
Make sure it is WifiTestCode and not WifiSetup.
Saltydogg
Post by Saltydogg »
Ok thanks Robert I'm going to call it a night and I'll attempt again tomorrow. Thanks again for all your help!
