over flow siphon
Spotted
over flow siphon
I have a hang on back siphon that I have setup in my controller to run for an hour every day. I don't want it to run all day long and the syphon works rather well and just needs a bit done every now and then.
What I want to do though is when ever I come out of feed mode or water change mode or any mode where the return pump is shut off, I want it to run for an hour as well. Is there a way to do this?
Thanks.
Also is there a way to puul the code from the controller into Arduino or does it only go from PC to controller?
Thanks.
Re: over flow siphon
Yes, we can come up with a custom function for you.
Unfortunately, there is not way back from controller to Arduino.
Try this:
ReefAngel.Init();
ReefAngel.FeedingModePorts=Port8Bit;
ReefAngel.WaterChangePorts=Port8Bit;
ReefAngel.Relay.On(Port8);
BackSiphon(Port8,Port1);
void BackSiphon(byte MonitorPort, byte BackSiphonPort)
static byte laststatus=0;
static unsigned long lastnow=now();
byte currentstatus=ReefAngel.Relay.Status(MonitorPort);
if (laststatus!=currentstatus)
laststatus=currentstatus;
if (currentstatus) lastnow=now();
ReefAngel.Relay.Set(BackSiphonPort,now()%lastnow<5);
Spotted
Sorry maybe a bit more info on what I need done. I have an aqualifter on the HOB overflow. I run that for an hour every morning.
I have it plugged into port 3 on my relay.
Will this code still let it run for an hour every morning?
Sorry..
Sorry..
Spotted
Here's my code with your code worked in. Did I do it correctly? Im a real newb at this.
// Autogenerated file by RAGen (v1.2.2.171), (06/11/2012 09:50)
// RA_061112_0950.ino
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 5
#define ENABLE_ATO_LOGGING
#define IOEXPANSION
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = ReefAngel.LightsOnPortsE;
ReefAngel.DisplayMenuEntry("Lights On");
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = 0;
#endif // RelayExp
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
//Adds Wifi function
ReefAngel.AddWifi();
ReefAngel.SingleATO(true,Port1,25,0); //ATO time out 25 seconds once every hour
ReefAngel.StandardLights(Port2,19,0,6,0); //Refugium Light on at 7PM off at 6AM
ReefAngel.StandardLights(Port3,6,0,7,0); //Overflow pump on at 6AM off at 7PM
ReefAngel.StandardLights(Port4);
ReefAngel.Relay.DelayedOn(Port7, 5); //Skimmer
BackSiphon(Port8,Port3);
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
Spotted
It works, but only stays on for a few seconds. I would like it to run an hour then shut off. I was hoping for an hour run time.
Oh, I'm sorry.
I just reduced it dramatically for testing and to make sure it is working correctly
Just change the 5 to the number of seconds you want it to run.
Spotted
No appologies needed. You do Amazing work and I am grateful. I was trying to figure out where the time value was on my own. I hate to be a bother.
Thanks!!
Thanks!!
Spotted
Ok, so can someone look at my code. I've been playing with it and when in feeding or water change mode ports 5&6 are supposed to shut off, but don't. Also, when in Lights On/Off mode the screen goes blank. How can I make it show Light On Mode or Lights Off mode?
Did I screw up my code?
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
//Light On/Off Ports
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.Relay.On(Port8); //Return Pump
ReefAngel.SingleATO(true,Port1,25,1); //ATO time out 25 seconds once every hour
ReefAngel.StandardLights(Port2,19,0,7,0); //Refugium Light on at 7PM off at 6AM
ReefAngel.StandardLights(Port4); // Nothing yet
ReefAngel.StandardLights(Port5,6,0,22,0); //Turn off powerheads from 10PM to 6AM
ReefAngel.StandardLights(Port6,6,0,22,0); //Turn off powerheads from 10PM to 6AM
ReefAngel.Relay.Set(BackSiphonPort,now()%lastnow<300);
Try this:
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
ReefAngel.DisplayMenuEntry("Lights Off");
Spotted
Thanks Roberto awesome job.
Now that everythign works the way I like it, Time to tackle the auto ATO refill. The jumpers needed for the main board are just regular PC bord jumpers, yes?
Spotted
Ok, this works awesome, but I need a little more control over the overflow's pump. Can we add another item to the menu that says "Overflow Clear" that, when selected, will run port 3 for like 2 minutes?
I would like to clear out the air in between feedings and water changes or whenever I might need to.
Thanks!!
Thanks!!
Spotted
Also can I run 2 return pumps on 1 port? I have a Mag 9.5 and a Mag 12 that I want to run on the same port 8. Will the port handle it?
Try this:
You should be fine with 2 pumps on the same port.
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
unsigned long clearsiphon=now();
prog_char menu5_label[] PROGMEM = "Clear Siphon";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label };
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
if (now()%clearsiphon<120)
ReefAngel.Relay.On(Port3);
